Hello, My dad and I have been building a 91 mustang convertible over the winter or the street/strip. The car will run in the mid 12's I'm wonder what type of roll bar I am going to need. I want to put the least bars as I can since the car is a daily driver and I want to keep it as stock appearing as I can
Thank Jon |
Liked 275 Times in 76 Posts
Do you have access to a rule book? It looks like on page 309 Section 21, page 3 of the ET Quick Reference Chart that Quarter Mile ET's of 13.49 requires a rollbar with a convertable. I am pretty sure it will have to be a min of 6 point.
No matter what you do, install subframe connectors. If it is a stick make sure you weld the rear control arm mounts. Check around where the seats bolt to the car and check the floor pan in those area's for stress cracks. Just some things to look for, especially if it is a factory stick car that has had a hard life. Sean
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 01-26-2013 at 02:22 PM. Reason: Corrected info |
This is the rules for ET class 2013 NHRA Rulebook
FRAME: 4 Permitted. See General Regulations 4:2. DEFLECTOR PLATE Mandatory on rear-engine dragsters. See General Regulations 4:3. GROUND CLEARANCE Minimum 3 inches from front of car to 12 inches behind centerline of front axle, 2 inches for remainder of car, except oil pan and headers. See General Regulations 4:5. PARACHUTE Mandatory on any car that runs 150 mph or faster. See General Regulations 4:8. ROLL BAR Roll bar mandatory in all cars (including T-tops) running 11.00 (*7.00) to 11.49 (*7.35), in convertibles running 11.00 (*7.00) to 13.49 (*8.25), and in all dune-buggy-type vehicles running 12.00 (*7.50) seconds and slower. Permitted in all cars. See General Regulations 4:10, 10:6.
Liked 3,231 Times in 982 Posts
Of course there are lots of vendors making Mustang stuff but I'd recommend trying S&W, they have several options and can recommend the exact bar to meet your needs.
http://www.swracecars.com/store/1979...OSCAR_153.aspx
#5 | |
Liked 5,147 Times in 1,964 Posts
Sean, I believe the old Lakewood style bar is still legal. One A hoop , one back support, one side bar. Not minimum 6 pt.... but maximum 6 pt.
Thanks Mark,
I did not see that in the rulebook for the ET classes. I missed the detail, it does show a 5 point. I agree on the SW bar too. Sean
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 01-26-2013 at 06:09 PM. |
Is this the style you are talking about
Mark, I had that kind of bar in a 10.90 car many years ago (with a OEM firewall) and was told not to come back with it....if you read 4:10 of the General Regs and view the illustration I can see how tech inspectors could easily interpret it as not fulfilling the book on a few fronts....just my 2 cents but see my earlier post...
