Old 01-05-2013, 11:42 PM   #1
Doug Domm
Liked 85 Times in 22 Posts
Default Tires come of the bead when out of air???
I have a pair of wheels for a friends car here and when the tires loose air they come off the bead. The car is on the lift so not worried about damaging the tires or rims. I personally have never had this happen before. Both the tires and wheels are brand new. M/T 9x29.5 bias on an 8 inch wheel. Anyone else have this happen?
Doug Domm is online now   Reply With Quote
Old 01-06-2013, 12:35 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Tires come of the bead when out of air???
Doug,
our dragster front tires do that
Larry Woodfin 471W
Old 01-06-2013, 10:43 AM   #3
Dick Butler
Liked 32 Times in 19 Posts
Probably would not happen if shape of tire cold and uninflated werent narrower than rim width. It is the fresh strength of the rubber shape pulling them off I would say. I imagine if it were a 5 inch rim it would not have a pull inwards to overcome the width of the rim.
Old 01-06-2013, 01:39 PM   #4
Run to Rund
Liked 56 Times in 29 Posts
That will happen if the wheels don't have safety beads--bumps around the rim inboard of the tire bead surface to retain the bead.
