Liked 20 Times in 15 Posts
finally I got my pistons done. now it is time for the pins. this is a forged TRW piston, race only. what is the recommended end play number, both min. and max.?
thanks Rod in AZ |
Liked 881 Times in 452 Posts
yes i am ready for the new strip in Havasu. it is now supposed to be 1000 feet for the fuel cars, although i do not know if door cars are going to run that or 660 feet. the track is to be all concrete. the track is less than 600 feet elevation and that will be good. there is talk of a track here in Kingman, i will hold my breath
Rod in AZ |
Rod,
I assume you're going to use the original tru arc locks. On those the min would be .010 and max .030. Any tighter would try and push the locks out during piston /pin flex and looser than .030 could hammer the locks hard enough to break the eyelets off. Spiro locks are a bit more forgiving and you could reduce the above numbers by .005. The "normal" groove is cut for a hard to find (now) .052 wide lock (common now is .042). Good luck. It "may" be easier to get the grooves widened for double .042 sipro or tru arc locks. Rebco Machine in Wichita Ks can do the mod for you. Randy |
#5 | |
