Liked 325 Times in 50 Posts
Anybody know just what they are aiming at? Maybe I'm just old and dumb (no comments). I looked at my stuff and really can't quite get a handle on it. I also looked at several old cars (Bruce, don't shoot me) and the configuration is basically the same from a 68 cuda, to present. I guess if you put bearings instead of bushings is the issue.
Jeff Teuton 4022 STK |
Liked 138 Times in 51 Posts
This is likely what they are talking about. I'm sure that GM cars have a similar set-up available to them.
http://www.qa1.net/qa1_motorsports/d...trut-bars.html |
#3 | |
Liked 364 Times in 138 Posts
Dave Turner SS/GT #1153 |
#4 | |
Liked 13 Times in 9 Posts
#5 | |
Those rods/shafts go from the lower control arm to the front of the K-member on each side. What's unusual is that the NHRA statement specifies the strut rods in the header. But in the body of the letter, they talk about the entire front suspension in general! So are they going to have suspension teardowns in the barn to look inside all of the pivot points now? Fords too! ![]() Last edited by Myron Piatek; 12-13-2012 at 08:09 PM. |
Liked 695 Times in 206 Posts
I put a call in today to a NHRA tech guy to help clarify what is meant by the wording in the post. I do not believe it is a worry to the GM cars, but could effect the Fords and Mopars with the front strut rods. Remember how an old Mopar would shimmy the front tires on lauch sometimes, that is what will happen again if this rule is enforced. The front strut rod has to be secured and stable for the car to run safely, especially at 150 plus MPH. This will not happen with the old Mopar setup, a long rod with two rubber bushings trying to hold it steady. Dyno
A few companies make replacement polyurethane bushings for the strut rods which are stiffer and more durable than OEM rubber.....and legal.
First gen Chevy II's have needed this mod. for atleast 40 years now..
I figured it was legal now..with all the GT FWD conversions out there... I guess safety is a not a big concern this week...They used it up last week on the Stocker seats. Remember...You need a roll bar in 12.85 Stockers ,,,for safety! On my 62 Tempest... (not a Class car) it was cheaper to fix the struts this way, than to buy the old replacement bushings. ![]()
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 12-14-2012 at 01:07 AM. |
#9 | |
Chad Rhodes 2113 I/SA |
Rhodes, I can read that. I'm looking for the deeper inner meaning. I'm gonna choke you next time I see you. We been using aftermarket bushings on our stuff for so long it isn't funny. Mostly availability issue. There is some adjustment in the strut on all the older factory cars, none on the new ones. I know about the bearings on the control arms. Is that those things with the rollers in a cage that you grease? Or is that a mystical circular device related to Stonehenge that will explode on Dec 21. Only the Myans know for sure.
