Old 12-06-2012, 09:06 PM   #1
Nathan Stinson
Nathan Stinson's Avatar
Liked 4 Times in 1 Post
Thumbs up Nova Subframe
This subframe was under my 74' Nova. It should fit any 68-74 Nova/Omega/Ventura and 67-69 Camaro/Firebird. On to the details: This is pretty much a complete package ready for your car. It has a driveshaft loop welded in it and a factory tranny crossmember. Midplate and motor plate for a small block chevy. The engine cradle has been cut and boxed for oil pan clearance, but all holes are still there for stock motor mounts if you need to use them. It has Fatman Fabrication tubular A-arms on it and rack and pinion steering. I also have a modified stock column that will bolt to the steering shaft you see in the pictures. It also has a tow hook welded in the center. To my knowledge the frame is straight and as you can see in the photos it is clean and ready to go. The lower A-arms have been modified for a coil over conversion Afco shock. All you need is the spring pocket to weld back in and it would accept the stock style springs. It does not have shocks and springs with it. $1300 for what you see plus the steering column. If anyone wants the Areospace disc brakes that were on it we can talk but the price will obviously be more. email stinsonn@bellsouth if interested. SOLD!!!!
Nathan Stinson is offline   Reply With Quote
Old 12-07-2012, 11:17 AM   #2
Todd Bailey
Liked 33 Times in 17 Posts
Default Re: Nova Subframe
Nathan,
You have a PM.
Todd Bailey is offline   Reply With Quote
