Old 11-08-2012, 10:24 AM   #1
Eddie Rezac
Liked 63 Times in 7 Posts
Smile Bump steer fix, early chevy 2
If you are having bump steering problems with your early chevy 2, I can help with a bolt on kit. Basic kit is $350.00, with a core. Eddie Rezac 402 443 8424 or eddierezac@yahoo.com
Eddie Rezac is offline   Reply With Quote
Old 11-09-2012, 05:43 PM   #2
Kenney Kelley
Liked 72 Times in 36 Posts
Default Re: Bump steer fix, early chevy 2
Can someone explain bump steer and how it effects a Chevy 2 ?
thank you Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 11-13-2012, 03:50 PM   #3
Eddie Rezac
Bump steer is when the toe changes, as the front end travels up and down. The early (1962-67) Chevy 2 is very notorious for this problem.
Old 11-13-2012, 05:40 PM   #4
Darrin Christen
Darrin Christen's Avatar
what exactly is included in the kit, and what is needed for a core? Thanks, Darrin Christen
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 11-14-2012, 03:36 PM   #5
Eddie Rezac
Smile Re: Bump steer fix, early chevy 2
The core is the drag link, and a good pitman arm. I reconfigure these, send them back with a new pair of special outer tie rod ends, plus installation, and alignment instructions. If you would like, for a slight extra cost, I can rebuild your idler arm assembly to perform better.
