Brodix Aluminum Block- half filled
Brodix Intake Brodix 365 3xtra-O Heads T&D 1.75 PAC Springs Manton Push Rods Crower Sever Duty .903 lifter Comp Cam 808/798 278/294 112LS Diamond Pistons Eagle Crank Eagle Rods Jessel Belt Drive Tital Oli pump Mildon pan Block, lifters, springs and cam where all new this season when motor was freshened.The rotating assembly has 2 seasons and roughly 350 runs. If motor does not sell we will check the lifters and run next season. Motor was in a 1900# swingarm dragster with 34.5 beadlock and 4.10 gear. Motor ran 4.70's/7.40's leaving at 4400 and shifting at 7100. Motor is well maintained and not run hard. Original block/motor combo was not hurt. Switch to aluminum for weight savings only. Motor will not have coil, water pump, vacuum pump or distributor. Asking $17,500 obo Call Dion at 330-584-3679 with questions or offers. |
