Old 09-10-2012, 11:00 AM   #1
Straightliner
Default Timer 2 caculation
Once I figure out my throttle stop factor/ratio. Where do I find how to do the actual math to know how much time to add or subtract from timer 2. I know you guys know how to do it but who taught you in the first place? I can't find it anywhere.
Thanks, I'm still learning!!!
Last edited by Straightliner; 09-10-2012 at 11:03 AM. Reason: I wanted to add the l in calcualtion, but it wouldn't let me!
Straightliner is offline   Reply With Quote
Old 09-10-2012, 11:37 AM   #2
Rick Bailey
Rick Bailey's Avatar
Liked 10 Times in 7 Posts
Default Re: Timer 2 caculation
Go to Biondo's web site, the is some great info there ! you'll learn all you need to know there.....
Rick
Rick Bailey 3439 SC
Rick Bailey is offline   Reply With Quote
Old 09-13-2012, 03:03 PM   #3
Straightliner
I have been there and read all of it. He tells you how to figure out your ratio. I'm asking where it's posted about the math to figure out how much time needed to run a 10.90 something. Example I had timer 2 set at .6 and I ran a 10.75, now I want to run a 10.90. my car has a ratio of 8:1. What's the math?
Old 09-13-2012, 08:47 PM   #4
Rick Bailey
8 to 1..... ? wow ! you might check that. however,
you need 15 hun of et change..... so you would use your 8. 8 x 15 = 120 add the 120 to your .6 to slow the car.
Most ratios are .... 2.0 to 3.0 depending on combo.
tell us what you have maybe we can help....
Rick
Rick Bailey 3439 SC
Old 09-14-2012, 10:41 AM   #5
Straightliner
Rick
I was getting help from some seasoned 10.90 racers. They came up with 8:1 after I made some passes with a little time then a lot of time in the box. I agree it sounds high and I may have to revisit that but the math was responding with that ratio for that weekend.
Rick who taught you the calculation to figure it out? Am I missing the fact that it's a standard math equation? Or is it customized for this application?
They used different math!! I have to wait 'til I get home and I will let you know his math. Bare with me.
Thank you in advance.
Old 09-14-2012, 11:50 PM   #6
RacingRicki
Sponsor
RacingRicki's Avatar
Straightliner,
Post up your times and the weather conditions and I will enter it into my software. It will tell you the ratio.
RacingRicki
RacingRicki is offline   Reply With Quote
Old 09-14-2012, 09:07 AM   #7
Bob Verwold
Bob Verwold's Avatar
I'm with Rick, I think your a tad high on your number. The best thing is seat time and good records.
You won't be able to slap up 10.900's all the time.
Do you have a good weather station ?
Bob Verwold is offline   Reply With Quote
Old 09-16-2012, 11:04 AM   #8
sc3912
Liked 6 Times in 1 Post
Could you define a "tad" high? Rick and I both run super comp and I know my ratio is around 2.8 to 1. I would consider 8 to 1 to be excessively high, but maybe in a heavier SST car the ratio will be higher considering the weight of the car and the HP of the car. What kind of ratio, and what kind of MPH do you run with your car? The car in question ran a 10.75 with only .6 in the timer 2 so it doesnt appear to have a lot of extra HP. Maybe it needs that much ratio to work. According to his posted numbers, the ratio he came up with appears to work. What does the car in question weigh and what does it run full out? I was looking at some of your posts in other topics and should ask you are you using the 3 speed or glide and are you shifting on time or by rpm?Also, what is your first timer?
Jeff Spierling
2007 Div. 3 S/C Champion
sc3912 is offline   Reply With Quote
Old 09-17-2012, 10:32 AM   #9
Straightliner
3500lbs, 3 speed turbo 400, so far it has gone 10.42 there is a bit more there but I need to get out to a test and tune day to find out.
540 bbc 700 hp crate engine. stop on @.300. Shifts into 2nd by time and into 3rd by rpm.
