Old 05-25-2012, 01:07 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Default big block mopar heads
my dad is trying to find a set of aftermarket heads(steel or alum) that will work with a dome piston. he has called several places and they tell him their heads will not work with a dome pistons. any info would help thanks hason ssja2021
jaf2021 is offline   Reply With Quote
Old 05-25-2012, 08:10 PM   #2
James L Miller
Liked 25 Times in 16 Posts
Default Re: big block mopar heads
What pistons do you have? If you don't have them yet, check Diamond pistons. Their piston is advertized: "Designed to fit most OEM open and closed chamber heads". I think Ross and others will tell you what chambers they are designed to fit.
Mopar 2 Ya!
Old 05-25-2012, 08:23 PM   #3
jaf2021
james
they are JE pistons is all i know we was running 915s
Old 05-25-2012, 08:23 PM   #4
GTX JOHN
I ran the Edel. RPM with Domed pistons and the Stage 6 Mopar for many years before that with domed. I used 2295 TRW Domed for twenty yearsor so (Still do in our Bracket Stuff). I Believe the B1 and Indy may take a
dedicated design dome and special valve pockets. The JE Sportman series should accommodate either of those
Entry level Aluminum Heads.......Check with JE (I think they are still in Huntington Beach, Ca.).
Old 05-25-2012, 11:17 PM   #5
James L Miller
http://www.jepistons.com/Catalogs/Au...edge_dome.aspx
They don't specify which dome(s) fit these pistons. I don't see a dome for the SRP pistons for a 440.
http://www.jepistons.com/Catalogs/SR...-440_flat.aspx
It looks like you need to call them. I'd figure they would design it for a 906 type head, but that is a guess.
Mopar 2 Ya!
Old 06-01-2012, 05:20 PM   #6
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
Call 440 source and see what they have. Their pricing is good.
rickseeman is offline   Reply With Quote
