Stocker parts 325-350/396
8 Arias C661 .030 pistons $350 8 Venolia 325/396 .030 $350 8 Venolia 325/396 .030 coated skirts $400 5 Lunati RL325-88 @107 $100 ea Lunati RL 325-3 $100 Bullit 290H8 S607 $100 Bullit S4884 S6772 72 288 284 74 $100 Line performance 948 Q-jet intake $300 8 unmodifyed 948 Q-jet intakes $150 ea. 948 Holley intake $175 067 Q-jet intake $150 Woodro Josey 948 Q-jet intake 3 290 small plug heads bare 2 need work $900 Mopar 904 case chevy bolt pattern $250 Dynamic Chevy metric freshend since last used $650 Turbo 400 trans. Alm. drums 2.48 T.brake $1200 Turbo 400 2.75 gear set $450 Turbo 400 2.75 straight cut gear set $500 Powerglide trans. stock case ,2.98,turbo shaft, Alm. drum ,Hipster alm, t brake valve body $1400 A-1 torque convertor 6000 stall for turbo built for SS 300-350 SP6558 350A-20 CZX 100 $700 12 bolt chevy 4.33 pro gear $225 12 bolt chevy 3.90 gear $125 Ford 9" 5.86 pro gear $225 Moroso front trick springs for 68-72 Chevelle or comp. GM bodys $75 Moroso weight box $65 2 M/T Frontrunners 29" 12 passes $150 2 Weld Magnums 15+10 5.5 rear space 4 3/4 bolt W/30+9 lightweight Hoosiers $700 SAR prepped late model Q-jet $595 2 Rodcester 4GC cores $150 ea. HP Q-jet kit Tk. top gasket .135 window n&s 2 4 hole tk. base gaskets fast cpa $60 Call Scott 803-210-8573 stocker204@yahoo.com Last edited by scott welborn; 05-10-2012 at 02:23 PM. |
Scott,
I will take the weight box give me a call thanks Doug
Doug Frazier D/SA 2038 |
You have a pm.
Scott,
Thanks again Doug
