Old 03-03-2012, 12:42 PM   #1
actionange
Default master cylinder question
Want to upgrade a 71 Cutlass to a more lightweight aluminum and plastic one to replace the lump of case iron now in the car. What fits and who makes one along with an adapter plate to take the 4 bolt config. to a 2 bolt style?
actionange is offline   Reply With Quote
Old 03-03-2012, 11:19 PM   #2
Run to Rund
Liked 56 Times in 29 Posts
Default Re: master cylinder question
Olds used two styles of iron master cylinders. One is slim and light, about 5 pounds.
Old 03-04-2012, 12:16 AM   #3
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: master cylinder question
Go to your local Napa store and ask to see a M-2456 master cylinder. Might just be what you need. I have a '68 Chevelle wagon that needs one.
Old 03-05-2012, 07:32 AM   #4
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
What is your brake system (i.e. Drum, disc/drum, disc/disc)?
I run the Strange #B3360 MC on my '70 Cutlass... disc/drum.
Slight modifications are needed....
http://www.summitracing.com/parts/STR-B3360
Old 03-05-2012, 05:02 PM   #5
actionange
Rallye Bob,
Please define slight modifications. Do you need a plate to mount it and if so where did you get it or did you fab your own?
Thanks
Old 03-06-2012, 07:38 AM   #6
rallye bob
rallye bob's Avatar
No Plate. Used the top two mtg studs (X-power brake car) on fire wall. Had to file the mtg holes in the master cyl. a little as they are narrower spaced, than the mtg stud spacing. also had to mod. the push rod to fit my peddle arm.... It was not difficult at all... Works great.
Old 03-06-2012, 08:54 AM   #7
SCOTT SST2871
no plate. Used the top two mtg studs (x-power brake car) on fire wall. Had to file the mtg holes in the master cyl. A little as they are narrower spaced, than the mtg stud spacing. Also had to mod. The push rod to fit my peddle arm.... It was not difficult at all... Works great.
x2 this worked on my 71 pontiac also
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 03-15-2012, 05:19 PM   #8
actionange
Thanks rallye bob. It was a simple installation with your imput.
