Old 02-05-2012, 03:49 PM   #1
Jack McCarthy
Liked 511 Times in 122 Posts
Question electric fuel pump question
no, not my race car... back to my suburban. i am going to put a fuel pickup in the bottom of the tank, and plumb it like my race car with an electric pump and regulator. plan is to put both in rear of vehicle...
here are my questions...
1. with say 7lbs of pressure should i still go through my mechanical pump ?
2. what pump would you guys recommend, remember flow is not as important as a pump that will survive 10-12 hours of continious running (i am going to belle rose straight thru!)
thanks,
captain jack
p.s. if this does not fix it i will have a 1991 suburban with less than 100,000 mile on it, brand new motor, brand new fuel system and absolutley no rust anywhere for sale ... DAMN CHEAP
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 02-05-2012, 06:04 PM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: electric fuel pump question
if it were me, i'd use an OEM/Delphi pump in the tank...notice the "oem" part of this, not airtex or another aftermarket piece of...
you ARE still running the stock throttle body efi for the truck, i'm assuming..?
Old 02-05-2012, 06:11 PM   #3
Ed Wright
Ed Wright's Avatar
I wouldn't use any aftermarket, or parts store replacement pump. Only genuine AC Delco. Btw, 7 psi is way low. 1991 TBI system needs 10 to 14 psi to run well. 12 to 14 preferred, especially for towing.
Ed Wright 4156 SS/JA
Old 02-05-2012, 06:36 PM   #4
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Lightbulb Re: electric fuel pump question
Be careful with the A/C delco stuff.Not the same old A/Cdelco we are used to.Take a look at Walbro or Ractronics they might have something for you
Kevin
Old 02-05-2012, 07:51 PM   #5
Ed Wright
Ed Wright's Avatar
Kevin
Don't know if you have a shop, or not. I made the mistake of installing too many Walbro pumps. Had to pay too many wrecker bills over failed Walbro pumps. I stopped buying that crap, and out of my pocket bought AC Delco pumps to replace them. I have had no comebacks with OEM plumps. Walbro was OEM for Chrysler, don't know if they still are. Chrysler had way too many pump failures also. From past experiences at my shop, I would never trust or recommend a Walbro pump.
Old 02-06-2012, 08:18 PM   #6
Peter Ash
Peter Ash's Avatar
Ed, was that back in the day when Shell Oil had to admit that one of their gasoline additives was eating up Chrysler pumps? I believe up here it became a warranty issue covered by Shell Oil via Chrysler.
Peter Ash is offline   Reply With Quote
Old 02-05-2012, 08:07 PM   #7
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
Kevin
Delco doesn't make their own pumps,actually Delco makes very few of their own parts. They contract out to suppliers such as Carter,Raybestos,National, BCA etc for many parts and get a lot of "mileage" out of marketing them under the AC Delco name. I have been in the parts business for more than 25 years and had managed an AC Delco distributorship for almost 10 years,before moving to NAPA.
Old 02-05-2012, 09:16 PM   #8
Ed Wright
Ed Wright's Avatar
I didn't buy AC pumps from parts stores, I ordered pumps from the GM dealer. Ford pumps from the Ford dealer. I avoided that kind of work on Chrysler products, since the local Chrysler dealership's parts departments did not deliver and their discounts weren't deep enough to make it worth the trouble of someone having to drive across town to pick them up. Ditto International Trucks. Haven't done that kind of work at all for a few years now.
Last pump I bought from NAPA said Walbro right on it. Forget now who's name was on the box. Bendix, Borg Warner, and non-GM AC Delco pumps were re-boxed Walbro also.
Old 02-05-2012, 06:37 PM   #9
Tom keedle
Tom keedle's Avatar
actually, NAPA sells delphi pumps nowadays...i THINK Car Quest does too..
Old 02-05-2012, 07:30 PM   #10
Jack McCarthy
failed to mention for those who did not get in the post back in october converted to carb motor ... q jet 454, th400
thanks... wish i had left pump in tank and added a regulator 5 years ago.
jack
"the Captain"
