Liked 336 Times in 183 Posts
Have a 2000 f250 diesel pick up---time to service the trans (its automatic) what if anything other than changing the filter and fluid needs to be done to the trans??? what is the best fluid and where do you get the filters ---looking for the best deal of course---thanx Comp
Liked 216 Times in 77 Posts
At my shop I buy the filters and fluid from the Ford dealer. Other makes I will use Napa stuff and have never had a problem. But if I use good name brand fluid instead of the ford stuff sometimes they seem to shift hard under light loads. I figure if I am going there to get the fluid I might as well pick up the filter too. Be prepared Ford is mighty proud of their fluid.
Liked 4 Times in 1 Post
I typically shy away from the dealers usually pompous ***&s and horrific prices when it comes to parts---- some of the OEM stuff you absolutely cannot beat in quality on the open market but other times they are so overpriced it can be humorous ---thanx for the response---Comp
Liked 3,252 Times in 989 Posts
AMSOIL, the only way to go for fluids in my book....for the tow vehicle anyway.
Liked 14 Times in 11 Posts
The Ford parts may be pricey, but they look pretty inexpensive compared
to Toyota parts............ And I own a 2004 F350 Super Duty that goes to the dealer for service and the wife ownes a Toyota that goes to the dealer for her service.
Phil Saran Parker, Colorado |
You should change the trans cooler to one from a 6.0 diesel. This will bring heat down quite a bit. And make the fluid and trans live a lot longer
Art Leong 2095 SS |
