Old 11-04-2011, 08:19 PM   #1
Mike W
Mike W's Avatar
Default converter help
I have a 8 inch coan converter 5000 stall, in a 81 camaro with a 383, bracket car.(set up like a stock eliminator car)
When i foot brake the car it tries to pull me thru the lights at 2200 to 2300, i have my 2 step set at 2000. I have a buddy with a 68 chevelle with a junk converter drum brakes and he can launch his car at 3500.
What do the stock guys launch at ?
Come on stock and superstock racers you guys are the best at getting the most out of your combos.
Thanks Mike
Mike W is offline   Reply With Quote
Old 11-04-2011, 08:45 PM   #2
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Default Re: converter help
Is it sliding tires or brakes not holding?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 11-04-2011, 08:54 PM   #3
Mike W
Mike W's Avatar
Terry brakes arent holding, the car keeps moving the more i bring it up on the converter. BTW if thats your corvette in the pics.... very nice car. Thanks Mike
Old 11-04-2011, 09:16 PM   #4
Liked 1,922 Times in 432 Posts
Mike, do you know what RPM the converter actually flashes to?
Do you know how much slippage you have?
What is your average ET and MPH?
Describe the car, weight, gears, tires, brakes, transmission, engine, etc. It help to know what we're looking at.
Old 11-04-2011, 09:30 PM   #5
Mike W
Mike W's Avatar
Alan i dont know what it flashes too and i dont know slippage.
1.52 60 foot 11.04 @ 124 best et 4.10 gears 28x10.5 slicks
QA1 coil conversion on front, split caltrac leafsprings and caltrac bars rear, competition engineering shocks on the rear, im going to caltrac shocks over the winter.
Stock disc front and drums rear
TH350 for trans
383 stroker
victor jr intake( ported to match heads)
950 hp carb from pro systems
eagle rotating assy 12.1 srp pistons
Cast iron dart sportsman 2 heads 2.05 1.60 valves ( ported)
all roller valve train
Ok i know you guys get alot more out of less so dont flame me to hard
Old 11-04-2011, 10:43 PM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
4.10 gears need to go first off,12-1 comp I'm pretty sure you are'nt cruisin much
I know you check flash when launching car @ track when you leave line watch where tach goes to as soon as hit the gas,it will usaully kinda hover there and then come back a few hundred rpm and then start climbing from there.
On slippage figure using formula, MPH X gear ratio X 336 divided by tire height= RPM
using info you gave if your converter had 0% slippage you would turn 6100 @ finish line.
figure % difference in 6100 and what you are crossing trap @ and that is % of slip you have.
Lowering rear gear will help reduce slippage @ finish line,but will also lose some stall on launch.
I'm bored while taking a break or would not even responded to automatic questionLOL.
PS i borrowed 4500 converter on time could hold brakes and bring up rpm keep easing down on throttle and could go over 6000 without moving car(junk) bought new one that flash 4100 about 2500 was as far as could hold it,worked on brakes got to 32-3300.
Mike Taylor 3601
Old 11-05-2011, 11:27 AM   #7
TH350 for trans
383 stroker
You should always know what your flash stall speed is, and how much slippage you have, it helps diagnose any problems you may have.
I'd expect a converter with 5000 flash speed to have about 3000 RPM "free stall", that's what you should be able to hold when you're on the starting line.
In order to make a torque converter "stall", you need torque from the engine, and resistance from the brakes and tires.
You need to make sure your engine is running well enough to make enough torque to create the stall speed you need. I've seen guys who have their engine running good at 5000 RPM, but it runs like crap at 2000 RPM, they think "it does not matter because I have 5000 RPM stall." But that is not true.
You may need to work on your brakes. You need soft pads and shoes on a drag car, especially with stock brakes, not the metallic materials, as you do not get them hot enough to work on the starting line.
Old 11-12-2011, 12:21 PM   #8
Hans Olsson
Hans Olsson's Avatar
Mike, are the front wheels locked and sliding as you bring the rpms up?
Hans Olsson is offline   Reply With Quote
Old 11-14-2011, 08:35 PM   #9
Mike W
Mike W's Avatar
No with the brakes pushed down it just pulls me thru .
