Liked 4 Times in 3 Posts
im sure you guys know starting next year all s st cars have to have a diaper. my 70 chevelle has a stock front suspension and front to rear engine placement. its a bbc with a moroso kickout pan with a scraper and windage tray.the pan had to be modified with boxed enclosures where the inner tie rods would hit the pan when against the steering gbox locks. also, the draglink is within .060 of the pan. my big question is how i get a diaper to conform to the pan where its been modified for the inner tierod clearance. looks like i will have to make a fixture and cut the center out of the drag link and fab a new piece thats lower for more pan clearance. this is a pain in the ***. i should just build a chassis car i guess
Liked 4 Times in 2 Posts
Check with Dennis before you do too much....@DRE
Liked 21 Times in 6 Posts
I might have already talked to you on the phone but if I did not give me a call 217-454-5289 We can take care of you.This what we specialize in is custom diapers,DRE has produced over 8000 diapers .Also headers are not a problem we have a diaper that is burn proof
it was me you talked to. wanted to see if anyone had any experience with a similar situation before i started removing the pan.see if there was something i hadnt thought of. can you tell me how thick the material is?
I always tell guys it is about as thick as a pair of jeans,Thin
Liked 229 Times in 99 Posts
How about a trans blanket, Dennis?
Floyd Staggs 787 SST |
