Liked 11 Times in 4 Posts
Any have any experience installing a Strange master cylinder on a first generation Camaro? I am converting my '68 Camaro over to disc brakes and I ran into a little snag.
The bolt pattern is about 5/16'' off and the adapter kit they give you seems a little bogus. Anyone have an elegant solution with or without the adapter kit they give you. Any pictures would be greatly appreciated. Many thanks! |
Liked 18 Times in 9 Posts
John, You don't need the adapter kit. Just slot the bolt holes outward til they fit.
Jim,
Thanks for the reply. I did think about doing that, but I was concerned that I would cause the master cylinder flange to become too weak. Is it stron enough to remove roughly an 1/8'' on each side? |
Liked 23 Times in 13 Posts
I slotted mine open both sides... It's been fine.
Gary |
Liked 6 Times in 4 Posts
Liked 536 Times in 110 Posts
Agreed. I wound up using the Strange pushrod with the OEM retainer and clevis. I also replaced the OEM pin and clip with a 3/8" bolt and "double nuts" so that there basically no chance of it coming loose.
Jim Kaekel 3836 STK |
