Old 07-17-2011, 04:21 PM   #1
jackarnew
Default air froil front of trailer
Dose any know were I can purchase an air foil ,air dam for the front of 24 ft. carmate goose neck trailer
jackarnew is offline   Reply With Quote
Old 07-17-2011, 09:56 PM   #2
FED 387
Liked 336 Times in 183 Posts
Default Re: air froil front of trailer
Jack ---the name of the company that has the patent on them is called NOSE CONE ---& I think thye are located in California---seems that any large trailer dealer should be able to get you one---also seems to me that they run about $500-800 depending on the size---some claim they get anywhere from 1-2 MPG improvement on a diesel but where they really work is in crosswinds or real windy days cuts down on the trailer jumping around all over the place---look em up under Nose Cone see if there is a dealer in your area or contact one of the trailer guys that advertise on Classracer--Comp
Old 07-21-2011, 08:00 PM   #3
jackarnew
Originally Posted by fed 387 View Post
jack ---the name of the company that has the patent on them is called nose cone ---& i think thye are located in california---seems that any large trailer dealer should be able to get you one---also seems to me that they run about $500-800 depending on the size---some claim they get anywhere from 1-2 mpg improvement on a diesel but where they really work is in crosswinds or real windy days cuts down on the trailer jumping around all over the place---look em up under nose cone see if there is a dealer in your area or contact one of the trailer guys that advertise on classracer--comp
thank you, i will try .
Jack
