Old 06-05-2011, 10:37 PM   #1
Mike W
Mike W's Avatar
Default best battery charger ?
I wanted to get some feed back on whats the battery charger everyone is using? Im charging a bracket car with 2 batteries. Thanks Mike
Mike W is offline   Reply With Quote
Old 06-06-2011, 12:10 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default Re: best battery charger ?
I have a Craftsman (stand up on wheels) that I use it has a 40 amp setting & also a 200amp jump start if your in a pinch.
Old 06-06-2011, 01:39 PM   #3
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Use a digital Craftsman if you can afford it. One of the best purchases I ever made. It will tell you exactly how much you have charged your batteries. Charge to the max volts if you have time. Make sure that you can reach the same voltage everytime. It will make your car more consistent. Without a digital guage you don't know if you are reaching the correct voltage or not.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 06-06-2011, 04:34 PM   #4
Mike W
Mike W's Avatar
Richard i looked on Sears website , are you referring to the battery charger thats called the microprocessor ?
Old 06-06-2011, 04:53 PM   #5
Richard Grant
That's the one. Expensive isn't it? It's worth it though. I have had mine about 10 years. I've used mine to charge the boat battery, the scooter battery, the golf cart batteries, the trailer batteries, etc. It will sometimes shock a old battery back into service by placing it on high until it takes a charge.
Old 06-07-2011, 09:26 AM   #6
ron mattson
Liked 69 Times in 32 Posts
I use a Schumacher speed charger, they are well built and show state of charge %
and charging volts plus have a setting for gel cell and agm batteries as well as conventional
types. Approx 100.00 here
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 06-09-2011, 12:38 PM   #7
k.pascoe
By far it has to be my old Snap-On charger. I'm at work so I don't have the model number. It's been ran over twice by a 4000lbs super stock car. And smashed another time by a 6800lbs Ford F350 dually. My god is it ugly, but yes it still works!!!
k.pascoe is offline   Reply With Quote
Old 06-15-2011, 10:58 AM   #8
Chris Barnes
We use a Powermaster that I bought from Summit. It charges 12 or 16 volts. It stopped working within a couple of months so I sent it back to Powermaster and they fixed it right away and it's been fine ever since.
Chris Barnes
Wagons of Steel
Stock 6621
Chris Barnes is offline   Reply With Quote
Old 06-15-2011, 05:21 PM   #9
tim worner
Liked 126 Times in 20 Posts
I have used the Black & Decker units with zero problems. I also liked the little 2/6/10 Husky unit that is fully automatic and very light weight and small in size but does a good job. Both are available @ Home Depot Also don't forget to use the batt maintainer when your car is sitting around unused. Really helps with the life of your batterys.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 06-24-2011, 12:15 PM   #10
Vic Santos
Vic Santos's Avatar
Liked 14 Times in 2 Posts
In my opinion any charger is good enough as long as it is big enough to do the job. The important thing is to monitor charger output VOLTAGE and not current. Voltage will tell you weather you are over charging or under charging the battery. If you are charging with the fan and water pump on unless the voltage is over 12.84 vdc you are not charging the battery. You are just providing current for the fan and pump. If you are pumping amps into a fully charged battery (because you forgot to shut it off) you will eventually damage the battery. The two things you need are: a timer that automatically shuts the charger off (part of a good charger) and a digital voltmeter to monitor volts at the battery. Until you know the voltage you won't know battery condition and weather your charger is big enough especially with two batteries.
Vic
Vic Santos is offline   Reply With Quote
