Old 06-05-2011, 12:01 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default car stumbles in the air!
We are having issues with the car as soon as you release the trans brake and it leaves the line and starts in the air it hesitates and acts like it is out of fuel. We have change 3 different carbs and regulator, fuel pump, msd box, we have looked at rotor button, distributor cap, and when car lands to runs fine and comes clean out of water boxs. any input would be helpful. thanks
TinSoldier 3215 is offline   Reply With Quote
Old 06-05-2011, 12:29 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: car stumbles in the air!
What car, engine, carb?
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 06-05-2011, 12:49 PM   #3
Jeff Lee
Jeff Lee's Avatar
If it runs fine everywhere except "x", then "x" is the only issue.
Running out of fuel either due to pressure or just's uncovered or sloshing fuel where it's not supposed to be. Maybe a wedge plate will work? But you have to look at the whole picture.
Jeff Lee 7494 D/S '70 AMX
Old 06-05-2011, 01:38 PM   #4
TinSoldier 3215
The car is a camaro, engine is a 350 and carb is a quadrajet. As far as Jeff's reply I don't understand what he's saying?? If the fuel pressure is off, then what should it be?? it has been 7lbs. When it comes out of the water box it has no hesitation, no stumble, it's just when u stage and go up on rpm's and release the trans brake button it hesitates and when it comes down and planes out, it runs great!! Do you think it could be a fuel pressure issue?? Thanks for any response...
Old 06-05-2011, 01:58 PM   #5
Dragsinger
Liked 99 Times in 60 Posts
Jones,
judging by your first post you have checked the basics for a bad part. So, it is reasonable to look at other items. [and do not mean any disrespect, just beginning the brainstorming process] begin looking at the entire package in a different light. That is to say, go back and look carefully at every small thing. Look at every wire, every ground, every terminal connection, etc.
One idea is to have someone else drive the car while you look and listen, might give a different idea of what is happening.
Larry Woodfin 471W
Old 06-05-2011, 02:00 PM   #6
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Fuel pressure or bad ground that only happens when you do a wheelie would be where I would start.
Bob Pagano A/SA
Old 06-05-2011, 02:50 PM   #7
TinSoldier 3215
And just to add the car is still in low gear. and I did have the trans brake button break on me and the wires touch. Do you think that the trans brake button by touching could have shorted sum thing out? Thanks for the help.. I'm stumped.. it's in low gear in the air.
Old 06-05-2011, 10:32 PM   #8
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
I went down this road a few years ago. After a new fuel pump,regulator, lines, coil, cap,wires, battery,cables, master cut off, blah blah blah it was a stinking wire that was grounding out against the frame. When the car was in the air it would touch and kill the engine. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 06-06-2011, 06:40 AM   #9
TinSoldier 3215
thanks to All for the help!!!!!!!!! Still Looking!!!!
Old 06-06-2011, 08:08 AM   #10
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: car stumbles in the air!
We had the same problem sometimes on the 88 Cutlass S/S move the regulator in front of the carb that way when the car launches the fuel in line will feed to bowl .
DIAPERMAN is offline   Reply With Quote
