Old 05-08-2011, 06:36 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question Cam question/help
I bought a 305 out of an 81 Z-28 the cam that was in it was a Crane part # 11-41-84 grind # ssh-310-nc I can't find any info on it.....anyone know what it is?
Old 05-08-2011, 07:06 PM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Cam question/help
Hi,
I found this on the Nasty Z28 website....
I don't know if info is correct????????????
Crane
114051 SSH-310-NC, hydraulic, rough idle, good midrange hp
Intake Open-Close BTDC-ABDC 40-90
Exhaust Open-Close BBDC-ATDC 88-42
Degrees Advertised Duration Int. 310 Exh. 310
Degrees Duration @ .050 Cam Lift Int. 236 Exh. 236
Running Clearance Hot Int .000 Exh. .000
Gross Valve Lift Int. .485 Exh. .485
RPM Range min 3800 max 6800 valve float 7000
Good luck,
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 05-08-2011, 08:11 PM   #3
greg fulk
greg fulk's Avatar
Red face Re: Cam question/help
Humm I just check lobe lift it was .314 that would make it 470 with a 1.5 rocker. Thanks for the info Bob
