Old 01-29-2011, 02:05 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Cooling system question?
Do you run a thermostate, a restrictor washer or nothing in
your cooling system?
It's a mopar 26" wide 3 row radiator with a 383 motor 10 to
1 compression, 10 inch convertor.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 01-29-2011, 05:25 PM   #2
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Re: Cooling system question?
I just have a washer in mine. it will get warm after 3rd run in a row, usually.
2894 STK
Old 01-30-2011, 03:12 PM   #3
Phillip marvetz
Phillip marvetz's Avatar
Restrictor with a moroso water pump drive.
2009 V/SA Record Holder
Old 01-30-2011, 03:34 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,248 Times in 988 Posts
I've been running no restrictors with filled blocks low compression motors, you may have to experiment.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-30-2011, 06:29 PM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Jim has the definitive answer....(you may have to experiment)
Old 01-30-2011, 07:05 PM   #6
FED 387
Liked 336 Times in 183 Posts
just a restrictor definately no thermostat tho---
