Old 01-26-2011, 12:40 AM   #1
paulbass
Question chev 12 bolt
a have a 12 bolt rearend was wondering what it came out of #3894860nf tube #bm 0213g2 A279 con1 can anyone help?
paulbass is offline   Reply With Quote
Old 01-26-2011, 01:56 AM   #2
KingReptile
Default Re: chev 12 bolt
68 Chevy II with 3:31:1
KingReptile is offline   Reply With Quote
Old 01-26-2011, 12:16 PM   #3
paulbass
Red face Re: chev 12 bolt
would you know if it was originally a posi unit. and i thought that the last number on the housing was the year?
Old 01-26-2011, 01:19 PM   #4
FED 387
Liked 335 Times in 182 Posts
BM is a 3:31 OPEN NOT a posi
Old 01-26-2011, 03:35 PM   #5
paulbass
could someone have changed the case because if i turn one side or the other both sides turn, even when i turn the pinion. inside it looks like on each side there is a plate w/springs. thanks for your help.Paul
Old 01-26-2011, 03:44 PM   #6
FED 387
The ORIGINAL rear end that came from GM was a 3:31 open gear---that is not to say that somewhere down the road it has not been changed to either a POSI or an entirely different ratio--- but as originally manufactured it was a 3:31 open ---sounds like ya got a posi in there whats the numbers on the gears???
