This is a 1971 Round Tube Chassis Camaro 4-Link Car.
Component List MagnaFuel Fuel System Autometer Gauges MSD 7AL3 Ignition MSD Crank Trigger MDS Pro Coil Stroud Parachute w/Launcher (New) Stroud Camlock Belts and Window Net Weld Alumastar Rear Wheels with GoodYear Tires Weld Alumastar Fronts with GoodYear Front Runners 7.50 NHRA Certification Strange Aluminum 3rd Member 4.10 Pro Gear Strange Double Adjustable Rear Shocks Wilwood Rear Brakes Wilwood Master Cylinder Strange 40 Spline Gun Drilled Axles 5/8's Studs Strange Front Struts and Brakes Hurst QuarterStick Shifter Dedenbear AS2 Air Shifter Dedenbear CC3 Delay Box Dedenbear TS6 Throttle Stop Carbon Fiber Drive Shaft Fire Suppression System for Driver and Engine Compartment Kirkly Seat SFI Roll Bar Padding Removable Mark Williams Steering Wheel Dual Optima Batteries Ron Davis Radiator Aluminum Rear Wing Removable Glass Doors Wheelie Bars Transmission is a Dynamic Transmission PG, Dedenbear Case with converter, trans cooler. The transmission is rated to 1500HP. 565 BBC Big M Block, Brodix Heads, Oliver Rods, Callies Crank, JE Pistons, Jessel Shaft Rocker and Belt, Complete Stef's Dry Sump system with pan. Alchohol Dominator, Moroso Fabricated Valve Covers, Dynatech coated headers. The car has run a best of 5.40 at 130 in the 1/8th and 8.35 at 165 in the 1/4. Please call 715-574-0951 if interested. Thanks, Jeremy Last edited by jjwoller; 09-16-2010 at 11:30 PM. |
Banned
you forgot price
Sorry, $29,500 obo, would also be willing to look at trades for a nice 64 - 67 Nova, 69 Camaro or 70 Buick 455 Stocker.
Thanks, Jeremy Last edited by jjwoller; 10-08-2010 at 10:10 PM. |
