Old 09-08-2010, 08:30 PM   #1
70chevelleracing
Default WTB 70 chevelle 2 barrel carb
looking to make my chevelle a stock elim car and looking to use a 2 barrel 350 due to the unpopular class it would put me into. just hope i can run the index. i think i need a roch 2gc - 7040113 or 7040114 i believe they say the sizes are 1686 or 1375 not sure the difference. any parts, thoughts or recomendations would be much appricated
Thank you
Dan Hyttsten
763-477-8806
hyttstenhomes@hotmail.com
70chevelleracing is offline   Reply With Quote
Old 09-09-2010, 05:18 PM   #2
Larry Fulton
Larry Fulton's Avatar
Default Re: WTB 70 chevelle 2 barrel carb
According to the NHRA Engine Guides for '69 & '70 Chevrolet, these are the correct sizes and specs
'69 & '70 Chevrolet Passenger Car
- with 350" SBChevy / 2bbl. Rochester
- 2GV Model (divorced choke) with
1.686 is the Throttle Blade Bore ( 1 11/16" ( 1.6875" ) with
1.375 is the Venturi / Bowl Section Bore Size ( 1 3/8" )
(these "Big Venturi" 2bbls, are the one's that all of the dirt racers wanted for years.... sometimes incorrectly referred to as the 500 cfm 2bbl. )
(note the '71 Engine Guide shows the SBChevy 350" - 2bbl. carb had been downsized to the 1 1/4" Venturi)
** NHRA Engine Guides for '71, '72, '73 & '74 Chevrolet's - Document the SBChevy 400" - 2bbl. as having the following carb specs.
1.686 is the Throttle Blade Bore ( 1 1/16" ( 1.6875" ) with only a
1.250 is the Venturi / Bowl Section Bore Size ( 1 1/4" )
Hope this helps!
Larry Fulton
Last edited by Larry Fulton; 09-16-2010 at 08:58 PM. Reason: clarification of previous statement
Larry Fulton is offline   Reply With Quote
Old 09-09-2010, 06:05 PM   #3
70chevelleracing
thanks larry
Old 09-09-2010, 06:20 PM   #4
BOBOLA
I may have what you are looking for, i will have to find them in the shop and will get back with you. Ran this combo in a Nova 25 years ago and did very well with it. Will let you know what i find.
BOBOLA is offline   Reply With Quote
Old 09-09-2010, 08:43 PM   #5
70chevelleracing
thank you i appricate it
Old 09-10-2010, 06:54 AM   #6
Steve Williams
I have one with the intake still attached.
Steve Williams is offline   Reply With Quote
