Old 05-15-2010, 08:50 PM   #1
Ray Menard
Ray Menard's Avatar
Question Comp Cam Break-in Lube (Part # 159-12)
Does anyone have any experience or knowledge about using this product as a "leave in" additive with a full synthetic oil (Mobil 1) for racing applications.?
Ray Menard
SS/CS (SS/DM & SS/EM)
#7386
Ray Menard is offline   Reply With Quote
Old 05-16-2010, 08:05 AM   #2
Ray Menard
Ray Menard's Avatar
Default Re: Comp Cam Break-in Lube (Part # 159-12)
Since we're told the newest oils don't have the needed additives (due to the need to lower additives to protect catalytic convertors) to protect our engines, especially under the stress of racing. Does this idea make any sense?
Ray Menard
#7386
Old 05-16-2010, 01:27 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
Yes, I try to get all my circle track customers to do it.
Adger Smith (Former SS)
Old 05-16-2010, 02:14 PM   #4
Ray Menard
Ray Menard's Avatar
Thumbs up Re: Comp Cam Break-in Lube (Part # 159-12)
Thanks Adger,
I appreciate your reply.
Ray Menard
#7386
Old 05-16-2010, 04:21 PM   #5
Run to Rund
Liked 54 Times in 27 Posts
My local Chevron distributor still carries the older CI4+ Delo 400 (15-40) oil. If the bottle says CI4+ but doesn't say it meets CJ, it will have the good additives in enough quantity for flat tappet engines.
Old 05-16-2010, 05:04 PM   #6
Jeff Lee
Jeff Lee's Avatar
Ray,
Are you talking about your roller cam SS/CS engine or something else? Because you don't need anything but oil for a roller.
If it's a flat tappet, get a hold of me as my shop has coatings to the cam and lifters. They have completed R&D and will soon be released. You can have race springs installed (460#'s +) and start the engine up and let it idle. No break in, no spring changes required. Applied to your parts or custom built from the shop. You can call me @ 602-418-9797.
Jeff
Jeff Lee 7494 D/S '70 AMX
Old 05-17-2010, 03:10 PM   #7
Ed Wright
Ed Wright's Avatar
Originally Posted by Jeff Lee View Post
Ray,
Jeff
Jeff, you still need good racing oil with plently of zink if it has much valve spring. I made the mistake of trying to break mine in on Valvoline in the silver bottle (says "racing oil", but it aint), and kept buring the ends off my intake pushrods, until somebody clued me in to the dark gray bottle. That one has "Not legal for street use" on the bottle in big letters. Comp was out of that additive at that time. Never had any problems with Mobile1 and that additive. Had good luck with Royal Purple also.
Ed Wright 4156 SS/JA
Old 05-17-2010, 05:35 PM   #8
Jeff Lee
Jeff Lee's Avatar
Ed,
I was addressing the cam & lifters being coated, not addressing the rest of the engine.
Although I've never used additives and haven't experienced those issues you mentioned, better safe than sorry and I see no downside in the additives.
Old 05-17-2010, 06:50 PM   #9
Ray Menard
Ray Menard's Avatar
Lightbulb Re: Comp Cam Break-in Lube (Part # 159-12)
Hey...just by chance, I picked up a copy of "Drag Racing Action" (July/10 Issue) and on page 31 there is an article titled "Blame it on...Clean Air". The subtitle is "The reduction of Zinc in oil will create wear problems". Contributors are Castrol, Comp Cams, Lucas Oil and Valvoline. Interesting reading.
Ray Menard
#7386
Old 05-17-2010, 09:06 PM   #10
Adger Smith
Guys,
Think of it this way... Zinc is to oil what Lead is to gas as far as wear resistance qualities. Remember lead built up wear barriers and when we had to do away with it it caused wear problems with Valve seats and guides.
Zinc does the same thing to cam and lifters and rocker assys. It builds up a protective wear barrier. No Zinc, No wear barrier. We even add a Zinc addative to the oil we use in an A/Fuel project I'm working on.
