Old 04-25-2010, 02:45 PM   #1
GarysZ24
GarysZ24's Avatar
Liked 256 Times in 103 Posts
Angry Brad Plourd, you were robbed last week!
A thread awhile back spoke about this last week, but I just watched the final of Super Stock between Brad Plourd, and Justin Lamb (ESPN'S coverage of the recent Las Vegas national event), and cameras don't lie...they showed two frozen shots of the finish line between the two cars, and Brad the nose of your car was at the back of the finish line stripe, while Justin's was just getting at the middle of it. However looking at the bodies as opposed to how much they covered the tires I can see why you lost...Justin's frontal area was lower than yours, thus allowing the ground effects of his cars nose to trip the finish line beam ahead of your front tire. You had the reaction time advantage by .007, and if your frontal area was 1-2" lower, than that outcome would've been reversed...that's messed up, because you lost a race you should've won!
The same can be said of the Super Gas final, because Dennis Paz's Willys clearly beat Mike Ferderers Grand Am to the stripe, but since Paz's Willys didn't have the ground effects that Ferderers Grand Am had, the nose of Mikes car tripped the beam sooner that Dennis's front tire...that's a bummer for both Dennis and Brad.
I wish either the rules committee would either ask N.H.R.A., to either raise the height of the sensor at the finish line so that older cars could use their frontal area to trip the finish line too, or that they'd lower them so that the winner will once again trip the finish line with their front tire ONLY...like they used to! Dan Fletcher lost a race he should've won (that he spoke about in is dragster article not long ago), because of the same thing. I spoke with an NHRA tech guy over this last week, and thus now feel they probably won't do anything to equalize this (even though they should), but I think it's messed up...what's fair for some, should be fair for all, right??? How does everybody else feel about it. I think I know how Dan, Brad, and Dennis feel about it!!! My .02 worth
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 04-25-2010, 03:18 PM   #2
Billy Pires
Liked 23 Times in 3 Posts
Default Re: Brad Plourd, you were robbed last week!
These cars with the magical front ends have been around now for almost 20 years. and some of the third gen F bodies can also trip the beams with the nose if the front tires are small enough, so make that 25 years. This is nothing new. Anyways if they lower the beams so the front ends cant trip the beams, great. I'm all for it.
Billy Pires 1414 STK, 1414 SS
Billy Pires is offline   Reply With Quote
Old 04-25-2010, 07:43 PM   #3
Shawn Blair
Shawn Blair's Avatar
I noticed the same thing, that finish line shot showed it really well. They need to lower the beam for sure!
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 04-25-2010, 08:50 PM   #4
Dennis Paz
Liked 5 Times in 3 Posts
Ouch
Dennis Paz is offline   Reply With Quote
Old 04-26-2010, 07:30 AM   #5
chevy620
Banned
Put a "stripe taker" flap on your car, if that is legal in the class. Al it takes is a small piece of aluminum underneath the front of the bumper to make sure you get the infra-reds to "see you car".
We put them on the Cutlass and it is about the same distance as a newer Camaro now and it trips the light whether I am on the brakes or on the gas. Needs to be about 5" off the ground in most cases at the stripe.
Try it, you'll like it.
chevy620 is offline   Reply With Quote
Old 04-26-2010, 07:36 AM   #6
Greg Hill
Liked 279 Times in 68 Posts
That low front end is a two edged sword unless your car does it every time. It can also cause you to break out if you're not expecting it.
Greg Hill 4171 STK
Old 04-26-2010, 07:04 PM   #7
GarysZ24
GarysZ24's Avatar
Originally Posted by Dennis Paz View Post
Ouch
Yeah Dennis, OUCH for you and Brad is correct. It was bad enough reading in ND recently about Dan Fletchers loss due to that, but to see your race and Brads...that's cold blooded man! I hope the people who are in the rules committee read my thoughts, and everyone elses too, because that wasn't right...the points and the money you & Brad missed out on (due to not fault of yours other than not having a low enough front end is what I'm getting at)! They've always said that there's strength in numbers, so if enough of us contact Glendora (like I already did with Fletchers ordeal), then maybe this will change. Maybe cars like this have been around for 10-15yrs, but not with outcomes like those you and Brad & Fletch went thru....Greg Luneack nearly lost his Allstars final when his opponent tried to do the same thing last year, but fortunately his tire nipped the other guys front end!
You stage a car with the tires, the race should finish with the tires too!!! Again my .02 worth...
Gary Hampton
'86 Z24,173 V6
Old 04-30-2010, 12:29 AM   #8
Dice
brad hawk you are correct. the only thing left to say is congrats. mr Lamb, U R A BAD MAN!!!
Dice is offline   Reply With Quote
