Old 03-29-2010, 03:21 PM   #1
rjarrell
Default quadrajet problem
quadrajet loading fuel on idle
adjusting air and fuel does not make any differance.
newly rebuilt carb
new fuel pump
new gas line feed and return to tank
new gas tank
350 chevy rebuilt , fresh start
any ideas?
rjarrell is offline   Reply With Quote
Old 03-29-2010, 03:33 PM   #2
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Re: quadrajet problem
May seem stupid, but i've done it so i'll ask, If the carb has been rebuilt, are you sure you have the correct body to top gasket? In some apps some are very close to right, but not right. Had one with the same symptons and thats what turned out to be. Also, the float could be too high, needle/seat stuck open or out of place
Old 03-29-2010, 03:36 PM   #3
raceewing
I just had the same problem on my thermoquad, had a bad float.
raceewing is offline   Reply With Quote
Old 03-29-2010, 03:51 PM   #4
rjarrell
did not rebuild carb myself
was sent to the Toronto area, to a company that rebuilds carbs.
Just making sure i cover all bases before i send it back.
I have also been told it could be a low vacuum problem, or a
fuel pressure prob. will check it out first. Thank's for the help.
Old 03-29-2010, 04:07 PM   #5
Mike Savelle
Liked 7 Times in 5 Posts
Talking Re: quadrajet problem
had the same problem . replace the float with a new one
Mike Savelle is offline   Reply With Quote
Old 03-29-2010, 04:28 PM   #6
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Check fuel pressure, some will piss by with over 6-7 lbs
Bob Pagano A/SA
Old 03-30-2010, 12:12 PM   #7
GTX JOHN
Liked 2,471 Times in 696 Posts
If you are going to race your car, the carb requires a fair amount of specialized mods. You didn't say if you used a generic rebuilder or race specialist. It could certainly be a simple fix as suggested and probably is.....I have found it a really challenge to make Stock/SS car idle (low vacume/lots of overlap in cam). Danny Ashley is the one that I recommend to rework one....very approachable and patient with me: #1 in my book!
Old 03-31-2010, 11:00 AM   #8
tj310
Everybody has their stories. I have found that a pure stock Quadrajet may work fine on a 10 sec superstocker...Thanx Trevor
Old 04-09-2010, 10:52 AM   #9
Marvin Robinson
Marvin Robinson's Avatar
In addition to the above, Check & make sure the that the top gasket is not binding the power valve needles - there is a slot in the gasket that the hanger has to go thru, and it can easily get caught on the power valve body when you install the top lid of the carb if you're not careful. Also, check for leaking at the fuel well plugs at the bottom. Sometimes they will leak when subjected to the carb cleaning solutions used, and most good rebuilders will seal the bottom of the well with epoxy, pipe plug, etc. Both of these conditions could cause unmetered fuel to drip or flow into the manifold, and render the adjustment needles unresponsive.
Marvin Robinson
3188 STK/SS
Marvin Robinson is offline   Reply With Quote
Old 04-09-2010, 12:19 PM   #10
Dragsinger
Liked 99 Times in 60 Posts
JT310,
I agree with your statement, however, there are some specific mods that help the drag race Q-jet. Experienced builders like Danny Ashley and Bubba Oliver know the "little" things that do make a difference. In some cases the difference is not much, in other cases the difference is enough to matter.
Larry Woodfin 471W
