Liked 3 Times in 2 Posts
I am getting ready for this season and finally have my car finished. In testing it has gone 9.7's @ 145mph. Am I better off racing it in S/G and just adding a little wieght? or should I put a stop on it and run S/ST?
The car is a Mustang that is mini tubbed with a 28x10.5 tire under it, small block Ford, it only wieghts 2600# now. I know most of the S/G cars are running high MPH but this is where I really wanted to race. Or should I just run S/ST get my grade points and wait till my new car is finished to run S/G? I am in the midst of building a new Mustang, on a 5 yr old Pro Stock chassis. But this will not be ready till sometime next year due to funds and the fact that I want to race a little this year. I have been off the track way too long and NEED to get back out..
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Liked 4 Times in 2 Posts
it Might be more competitive in Super Street....but who knows....can it cut a light in Super Gas....that would be your deciding factor.....
I can go red on a .400 tree , so "IF" I can dial the box corrextly as well as myself then yes it can cut a light.
you will have to add 200 lbs to run superstreet i think the weight needs to be 2800, you will be one of the faster cars
IMO I would put a stop on it and run S/ST
BB |
I'd add a little weight and run S/G..........
Thanks Barney.... |
Banned
You don't have to be fast to win....if you can cut the light and run the number, you are going to win rounds.....it is a blast shoving fast cars out the door....they will almost always want the stripe...until they get to know you then they wise up. I always say I don't start looking until at least 800 feet, why, because they aren't there! Consistency is the name of the game. All of the classes are tough....look at who wins in one year and with little exception, they don't do that well again the following year. There are a few top ten players every year, but a lot of turnover too.
Many guys run S/ST all year and then run S/G at the Nationals if S/ST isn't contested. I would put a throttle stop on even for S/G. I am probably the slowest car in Super Comp and run on the stop. I won Stanton a year ago with the stop predicting negative numbers! It was on for .05, that's it.... finished 3rd in Div. 3 that year. Advantage with the stop is it is easier than messing with weight all day. Plus changing weight changes the reaction of the car. With that being said, I do think there is an advantage to being the faster car, but just like being the slower car, you still have to learn to judge your car and make it consistent. Either way, its a blast. Good Luck this year! Ron & Meridee S/C at 150mph! (on a good day)
Ron Finney 396V S/C |
I have to agree. If you're planning on running in S/G next year or the year after with your new car (most certainly with a throttle stop), why not put a stop on this car to get some experience working with a throttle stop? Sure, the ratios will be different, but you'll learn a lot using the stop on this car, and you could transfer this knowledge to your new car.
As for S/St vs. S/G, I think you made the right decision to run S/St with this car.
Jason Oldfield S/G & S/St 1838 |
