Go Back   CLASS RACER FORUM > Class Racer Forums > Top Sportsman and Top Dragster
Old 01-08-2010, 03:48 PM   #1
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
Default Top Sportsman - Top Dragster Racepak
This is my most popular combo for TD - TS guys. Most are spraying 1 system and need to know what the car is doing during limited qualifying shots.
And if you are spraying for the first time, the 2 secrets of consistency with Nitrous; monitoring BOTTLE PRESSURE, and good record keeping with TIMER SETTINGS. Call any of the Nitrous wizards out there and ask what a 50lb change in bottle pressure will cost you in HP. Or what .020 in timer 1 will do. I can tell you from personal experience timer 1 can kick your butt!
This kit will put you on track! Don't wait till August after loosing early or maybe not even qualifying for the first couple of races.
Includes:
- Sportsman Logger kit
- Fuel pressure sensor
- Nitrous bottle pressure
- 12' Vnet cable
The sportsman logger kit includes:
- Engine RPM, Shaft RPM (with collar)
- Voltage
- Gmeter
- Software
- 12 volt event (like trans brake release, throttle stop, nitrous enable etc)
- Laptop accessories (this is big believe me)
Note that Sportsman kits are shipping the end of January.
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
Old 02-04-2010, 10:48 AM   #2
Mountainmotorman
Mountainmotorman's Avatar
Default Re: Top Sportsman - Top Dragster Racepak
This is a great package for a sportsman. I am not sure it would be good for T/S though since you can not expand with other sensors.... You can only use ONE NOS system when most are using 2 or 3 now.... No shock sensors.... Yet, it is GREAT for a regular sportsman with a lower budget as, it gives great info for the dollar you spend!
_
Mountainmotorman is offline   Reply With Quote
