Liked 54 Times in 7 Posts
Does anyone out there know of a source of a fitting that will thread into a stock TH350 transmission case and get me to a -6AN male fitting? The case has an odd thread that I believe is a 1/2" BSPP thread. From the factory there were brass adapters in the ports to connect to the steel tubing with an inverted flare fitting which I am currently using to get me to -6AN hose but it takes too many connections (possible leak points) so I want to clean up the plumbing and install some quick disconnect fittings on the trans lines, but all the kits that are available that I have seen either have 1/4" or 1/8" npt threads which will not work in this application.
Thanks Chad |
Liked 883 Times in 237 Posts
ATI has the proper fittings you need . #6an x straight thread ,with a gasket seal .....You can find them from Parker hydraulics in steel,if you have a counterman willing to take the time to look it up for you. .....Tom
Liked 535 Times in 110 Posts
Tom is correct, the ATI fittings are the best way to go. Most people use 1/4" NPT pipe to -6AN adapters, but be very careful tightening them.
Jim Kaekel 3836 STK |
Is the thread for the trans. line on a stock 350 case a 1/4 NPT?
Nelson Kowal Stock 345 |
Yes, the TH-350 is 1/4" NPT, as is the TH-400. I think all NPT to AN adapters made by Aeroquip, Earls, etc. are tapered NPT, rather than the OEM which is not tapered and uses a sealing washer. You can definitely crack the case if one of these type of adapters is over tightened due to the fact it is tapered.
I talked with ATI tech and they have 1/4"-18 fittings that have the straight thread that is in my case. The pitch is 18 just like 1/4" NPT but it is straight. I found that there is a NPS (National Pipe Straight) thread that is used on low pressure hydraulics.
Thanks, Chad Last edited by Chad E532; 12-23-2009 at 01:46 PM. |
