Old 12-20-2009, 03:41 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question exhaust?
getting ready to put the bracket/street engine in the Z-28. it is a 350 chevy flat top 487 head engine with a preformer cam & intake. right now it has a 600 holley but I'm going to put a Q-jet on it. it has a 350th with a 10" B&M holeshot converter with 3.42 gears. the car has 3/4 length 1 5/8 headers. what size exhaust to go with? 2 1/2 or 3" ? I'm going to put a set of 40 series Flowmasters on it with dumps. thanks guyz!
Old 12-20-2009, 06:48 PM   #2
Marvin Robinson
Marvin Robinson's Avatar
Default Re: exhaust?
I would recommend the 2-1/2" for a street/bracket car, your engine combo is fairly mild, and the larger pipes won't add any noticable power. The 2-1/2" might also have a little more low/mid range torque, but not enough to get excited about -- the smaller system will be substatially quieter on the street as well. Unless the ultimate 7-10 hp you MIGHT gain with the larger/louder/more expensive and harder to fit system is your goal, stick with the smaller stuff.
Marvin
Marvin Robinson
3188 STK/SS
Marvin Robinson is offline   Reply With Quote
Old 12-20-2009, 08:25 PM   #3
greg fulk
greg fulk's Avatar
Very mild combo! I hope it runs in the 13's. It ran 12.88 @ 104 in dad's 67 camaro with a 750 double pumper a 9" 4200 converter & 4.11 gears.
Old 12-21-2009, 07:45 AM   #4
Robert Simpson
Liked 20 Times in 12 Posts
Thumbs up Re: exhaust?
Greg,
Put the 2 1/2" on it you don't need the aggervation and expence of the 3". I have the same exhaust on my 70 nova with the dumps right at the rearend. It can get really loud and resinate real bad at certain RPM's. One other thing if you sit in traffic, which I do at times the exhaust will fill up under the car and it will start to come inside the car. If I did it again I would run the exhaust to the bumper or at least behind the tire. This is just what has happened to me. I drive my car more than I have a chance to race it. If you really want to test it out. When you get your exhaust finished, put a fitting for a pressure guage in fron of the muffler, make a run and at WOT look at the guage, if it is like 5psi or more you need a bigger exhaust.....Just a thought. I would like to see what that converter you have stalls at on the footbrake, when you get it running. Good Luck looks like a good combination.
Robert
Robert Simpson is offline   Reply With Quote
Old 12-21-2009, 05:23 PM   #5
rick winchester
Liked 208 Times in 35 Posts
Greg,call me. I have a nice used set of flow masters and complete exhaust on a 74 camaro that I am working on. The reducers are welded along with the mufflers and tailpipes. 513-733-3643 at home or 513-243 -1042 at work . Rick
rick winchester is offline   Reply With Quote
Old 12-21-2009, 08:09 PM   #6
greg fulk
greg fulk's Avatar
Wink Re: exhaust?
will do Rick!
