My malibu wagon is a 79-Do I run dished pistons or flat tops? I lost my Nsa and msa tech sheets. gonna look at work tomorrow. I have bracket raced my wagon for 20yrs and did fair. I hope to find out about what specs to run on cam, Can I use crane roller rockers? Thanks for all the help so far. Some of you make me not feel so lttle knowing that I don;t have much to start. I am calling this Welfare stock racing. I never live above my means, Only do this after all bills are paid. I have this dream to be able and run 3-5 tenths under index helps lift my spirits some. I am going to try and run the stock 7.5 posi rear for one yr.
#2 | |
Liked 19 Times in 7 Posts
Id rather run 1 tenth under the index and know that the rear end will live more than 2 passes rather than take a chance and break it at half track and hit the wall or the car beside you. Food for thought... ![]()
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Before you go any further, you need a copy of the rules. I suggest you find someone who has an extra copy of a recent rule book, like the 2009 rulebook, that they'll loan you or give to you.
You cannot run roller rocker arms in Stock in NHRA. You should not try to run a 7.5" 10 bolt, you can run an 8.5" 10 bolt, an 8.625" 10 bolt, or an 8.875" 12 bolt, but that 7.5" 10 bolt will likely break, and then you'll have to build a good rearend anyway. To find out what class your car fits, and what engines you can run, you look in the Stock Car Classification Guide. To find the specifications on the engine, you look in the Engine Blueprint Specifications. To find these lists, go to the NHRA website, and click the "Competition" tab. You'll also find the accepted connecting rod list and the accepted piston list. Good luck.
Alan Roehrich 212A G/S |
#4 | |
Banned
Liked 235 Times in 110 Posts
The roller rockers are legal in IHRA ONLY and they have to be the correct rocker ratio. 1.5 in your case. |
Liked 780 Times in 194 Posts
Look here:
http://www.nhra.net/tech_specs/engin...ts/CHEV-79.rtf Dished pistons. Cam .373" lift intake, .410" lift exhaust. Don't overlook the 2-bbl engine. At 180 rating, it's a viable option. |
They won't let me in that site. It comes up then says enter my 25 digit code off my CD. Product info something/any help?
