Old 10-23-2009, 10:12 PM   #1
pro70z28
Default Firewall Project
I'm ready to rebuild the firewall. I cut the flanges out today for the intercooler tubes to pass through the firewall. I'll turn them down on the lathe & weld them in place & shape the sheet metal around them.
pro70z28 is offline   Reply With Quote
Old 10-25-2009, 07:36 PM   #2
pro70z28
Default Re: Firewall Project
Got the flanges turned this weekend.
I put a groove around the edge of the flange for the firewall sheet metal. Once I install the o-ring and get in place I'll check the new gap with a feeler gauge and make a soft gasket to seal the flange to the firewall
Old 10-25-2009, 07:38 PM   #3
pro70z28
Engine side of the flange bored to size for the tubes.
Got everything mocked up. The flanges on the windshield will be added to the inlet side. I'll turn those once I get the V-band clamp. Should be here any day. The outlet side attaches to the carb bonnet with hose & clamp.
Old 10-26-2009, 04:52 AM   #4
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
No "flex" joints?
Old 10-26-2009, 02:49 PM   #5
pro70z28
Originally Posted by rallye bob View Post
No "flex" joints?
Yes, they will be beyond these. This is to get the tube through the firewall only.
Old 10-27-2009, 08:49 PM   #6
pro70z28
Made a little more progress. I put the ol' foam mock up engine in it to make sure I get the angles right before going too much further. (Joint will go where the dark red tape is).
