Coan th350 lightwieght with all the tricks
$3800. call jeff 573 450 9586 |
Liked 225 Times in 88 Posts
What gear set/ratio is in it ( straight cut or helical gear set ) ? Valve body reverse only or the clean neutial / double" N" set-up... TH350 in put shaft ? Trans brake ? How heavy of a car is it set up for ? Ken R.
Ken
The gear set is strait cut and has had treatment work done. The v body does have two nutrals. the input shaft is pg. This trans has all that is avalible and is fast. Its been in a 3400 lbs car at one time. |
Liked 11 Times in 8 Posts
Jeff, I may have asked this before but what ratios? Joe
Joe Buchanan SS/BX 3117 |
Joe,
The ratios are 2.17-1.44 Jeff |
Was this behind a big motor? Doesn't have much low gear. Would you know the cost of changing ratios? Joe
