Liked 1,988 Times in 600 Posts
I bought a super stock engine with a set of Childs and Albert steel rods in it. They look similar to a stock 350 chevy rod. The rod bolt looks like a 3/8 ARP wavelock type bolt. I need the torque spec for this rod. Thanks
Mike Pearson 2485 SS |
Liked 1,952 Times in 439 Posts
Mike,
If it is an ARP bolt, you can usually call ARP and get a torque spec and a stretch spec. If you ever start using a stretch gauge, using a torque wrench on rod bolts will make you very nervous.
Alan Roehrich 212A G/S |
Liked 30 Times in 17 Posts
Mike,
Contrary to what Alan said, I have had no luck at all getting ARP to give a torque or stretch spec unless the bolt is one of thier packaged part numbers. As soon as you state that the bolt is in an Eagle ( or C&A, or Scat) rod, they tell you to call the manufacturer. I am under the impression that different manufacturers use the same bolt with different torque specs, and this has been the case several times. I would call C&A and ask them to be sure.
Bill Koustenis |
Liked 978 Times in 313 Posts
C&A is out of business. Try recalling ARP and crying on their shoulder.
ARP will normally give you a spec IF the original manufacturer of the rod gives one, ARP will have it. If the original manufacturer of the rod does not give a spec (for example, Eagle does not give a stretch spec on some of the SIR rods) then ARP will not have the spec to give.
If ARP does not have it, then you might try a vendor who used to sell C&A products. They may have an old catalog. Normally I save those. I also save the spec sheet on parts, but I don't have anything on C&A rods. If you do not know what they were originally torqued or stretched to, I strongly suggest that whatever spec you decide to use, you torque them up in a vise outside the engine first, and have them checked for size and roundness, just to make sure you don't create a problem.
Alan... your a wise man...
Bub Whitaker |
Bill Koustenis |
Thanks Al,
That is the rod that is in this engine. I knew someone would have an old C/A catalog out there. Thats the great thing about this site We all try to help each other out. Thanks for taking the time to look for the information that I needed.
