Old 07-15-2009, 02:21 PM   #1
Casey Miles
Liked 508 Times in 92 Posts
Smile E85 gas
Since everyone is going "green", I was thinking that NHRA should allow the useage of E85 in SS/S classes.
Have the original carbs upgraded so that they can adapt to the E85 gas and allow the racer to get away from the ridiculas price of the race gas that is mandated. The E85 gas is about 104 octane and can run with an engine that has 14:1 compression. I for one would gladly change over so that there is nothing but good stuff coming out of my tail pipes instead of carbon and lead. There could also be a promotion from NHRA that their eleminator classes are doing good for the inviroment.
Casey Miles
248H
Old 07-15-2009, 03:31 PM   #2
BlueOval Ralph
Banned
Default Re: E85 gas
Hold on not all that easy as updating carbs!1 Some oe the old cards may not have big enough internal passages. Need more E-85 than gas + bigger fuel pumps & regulators, may need new fuel cell/tanks & lines. Carefull what you wish for! You need to research this fully.
Ralph
Casey Miles
248H
BlueOval Ralph is offline   Reply With Quote
Old 07-15-2009, 07:00 PM   #3
John Kelley
Default Re: E85 gas
WHOA.......it'd be a 150 mile roundtrip for me to get a can of that stuff !!!!!!
And a whole new fuel system and a HOLLEY CARB........NHRA wouldn't like that !!! :-)
It is not a simple switch over at all.....and not cheap....
John Kelley is offline   Reply With Quote
Old 07-15-2009, 07:16 PM   #4
Liked 1,952 Times in 439 Posts
Default Re: E85 gas
The quality of E85 is so completely inconsistent that a couple of carburetor companies actually sell testing kits so you can verify the alcohol content. Which has been known to vary between 70% and 90%, give or take.
Old 07-16-2009, 07:52 AM   #5
Casey Miles
Default Re: E85 gas
I'm not saying you need to run E85 in SS/S, but allow it as a spec fuel. As for a Holley carb, well I guess all the older vehicles it came standard equipment. I for one would switch over for sure because I'd rather spend $2.23 a gallon on E85 (also which is government subsidized) then $6.00 a gallon on Sunoco purple or the bigger ripoff VP C12 @ $10.50 a gallon. Racing is expensive enough and alternatives should be allow to reduce costs at all levels.
Casey Miles
248H
Old 07-16-2009, 08:54 AM   #6
Tim Ellis
Liked 7 Times in 6 Posts
Default Re: E85 gas
I wish theyd allow a pump gas unleaded premium fuel. My 89 mustang stocker/ bracket car runs 12.61 on unleaded premium, under $3 a gal, but c12 is over $ 8 by the barrel
Tim Ellis is offline   Reply With Quote
