I need a set of 5.13 gears for a Ford 8.8 rearend, new or good used. Thanks. Rory (604) 589-6883
Liked 275 Times in 76 Posts
Rory,
I had a hard time even finding this one? http://www.4wheelerssupply.com/catal...ducts_id/71196 Good luck. Sean
Liked 335 Times in 182 Posts
Try Ron;s Machining Service in Michigan $210 each
Liked 4 Times in 1 Post
Rory =
Jawsgear.com has them for $179. These are the Motive gears that I run. The ring is back-cut so they are alot lighter than other gears I've used. Earle
Earle Holt 1055 Stock |
Rory that is what I run Motive back cut had no problem getting them
Marshall Greenwell K/SA |
Thanks guys, the 5.13`s I was using until I broke the pinion this past weekend also had the back cut ring gear, I bought them from Moser 3 or 4 years ago. I found a set of Yukons locally, so I should be OK, but I will keep Jaws gear in mind and may buy another set of Motives for "next time". Earl, how long were your 5.13`s lasting for, with the stick?
