Guest
Posts: n/a
I'm looking for a small block chevy Canadian 2 barrel intake with the casting # 3916313. If anybody has one they want to sell please contact me. Thanks....Todd1153@aol.com
What motor did this come on ?
Danny Waters, Sr / 73 Duster "340" |
Liked 354 Times in 120 Posts
They are on the 400s, circle racers use them for the 2bl class lots bigger.
Tom Meyer 5240 SS Stock ??? |
Ok , can't help you now. No 400 stuff. But will ask around
Liked 2 Times in 2 Posts
Tom,
i'm not sure your statement is correct that the canadian manifold is "bigger" than the 313. We ran back to back tests on a street stocker (circle track car) and there was no difference in power. So, we sold it to the competition. If your running a class car that requires the 313 the you need to get ahold of guy by the name of brzezinski at www.cast heads.com. If your not restricted to the 313 but has to be cast iron then start looking for the following, and i'll tell you now there hard to find but worth it. The casting numbers are as follows 14088674 or 14088675. They originally came on bus's/trucks in the late 60's early seventys. The quick visable difference is that the carb. Pad (plenum area) is 3/4 inch (lil mini tunnel ram). Taller than the 313. Danny, haven't talked to you in a while, hope everything is well..... Norm |
Guest
Posts: n/a
The Intake fits 1969 and 1970 350 chevy engines. This is for a 69 Camaro M and N stock car that is going to be built.
