Old 06-13-2009, 07:33 PM   #1
Tim Ellis
Liked 7 Times in 6 Posts
Default 5.0 stocker rear control arm bushings
Hey 5.0 stockers, racers, which rear lower control arms are you usung? I've got Lakewoods with poly bushings. As I drive around tight corners with the 30" radials the rear is obviously moving around and the rear tires start rubbing the front of the body at the lower front wheel radius. I know its gotta be the poly bushings fighting the slicks and mini spool. It centers back up on straight aways, but I dont like the rub. I think an aluminum or solid busing would help. Im sure its just because of the large diameter tires but its not a good thing to rub.Thanx
Tim Ellis is offline   Reply With Quote
Old 06-13-2009, 07:46 PM   #2
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: 5.0 stocker rear control arm bushings
Global West has a nice lower rear arm with a spherical bearing in the front and their Del-a-lum bushing in the rear
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 06-13-2009, 11:22 PM   #3
Notch1320
How much of a gap did you leave when you opened up the wheel openings? I run HP Motorsports Magabite Jr's.
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 06-14-2009, 07:55 AM   #4
Tim Ellis
Sitting in my garage right now there is 5/8" clearance in the area where it rubs on cornering. So its moving a bunch.
Old 06-14-2009, 08:10 AM   #5
west coast
Liked 230 Times in 75 Posts
BMR fabrication Inc. has nice looking stuff with Teflon lined spherical bearings they are the nice ones out there I could find. I had to fab my own up, bearings were only about 7 bucks each from Midwest controls. Have you trimmed the front and rear of your wheel openings yet I was able to take out about an 1 1/2" off the front and some off the rear to help make the 30" radials fit nicely.
west coast is offline   Reply With Quote
Old 06-14-2009, 08:53 AM   #6
Tim Ellis
I dint trim the body, but rather used a ball peen hammer to roll the lip in, still I would think 3/4" movement of the rear forward is alot.
