Old 06-06-2009, 12:15 PM   #1
Lynn A McCarty
Lynn A McCarty's Avatar
Default Motorhome Error codes
Can anyone provide engine error codes for a 1998 Winnebego Motorhome w/GM chassis Class A Vortec 454 L-29?......and the procedure for determining them? Cant find it anywhere!
Frustrated,
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 06-06-2009, 01:04 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Motorhome Error codes
I am asuming you mean check engine code numbers. You will need a scan tool or if you goto autozone they will usually pull them for you. If you get the numbers and send them to me I would be happy to look them up and tell you what they are. The aldl connector should be beside the doghouse on one side or the other or under the dash on drivers side. Unfortunetly the days of retriving codes with a paper clip ended in 94
Old 06-06-2009, 04:07 PM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
well, 95 actually....
althought there was some obd2 in 95...
and yes, you'll need a scanner..
Old 06-06-2009, 07:10 PM   #4
Ed Wright
Ed Wright's Avatar
Actually, 1993 for some GM passenger cars. Like the LT1s and many 3.1L V6 FWD cars. I get calls all the time from guys trying to pull codes from those cars with a paper clip. It's pretty much plug-in proms you can, flash memory you can't.
Ed Wright 4156 SS/JA
Old 06-06-2009, 07:13 PM   #5
njk53
Actually, GM started to phase in OBDII in 1994. My dad's 94 LeSabre has it.
Nelson Kowal
Stock 345
Old 06-08-2009, 09:44 AM   #6
Ed Wright
Ed Wright's Avatar
Actually, the OBD2 style connector under the dash does not make the vehicle OBD2. 1994 LeSabres were still OBD1. The '94 & '95 GM vehicles with the newer connector do not have the class 2 data terminal and wiring. The '94 & '95 Corvettes, and 1995 F body cars all have the OBD2 style connector below the dash, but are not OBD2. Actual OBD2 GM cars and trucks came along in 1996.
Old 06-09-2009, 12:40 PM   #7
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
You can now buy a cheap scan tool from Kragen that will read any OBD2 code and give a breakdown
on any vehicle equipt with OBD2 or you get a little nicer one from Mac tools that does the same and has
some extra features such as Web updates and comes with a cable for USB. I have the MAC one and it works great lets you also Clear the codes. Cost $100.00
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
