I have a super street car that runs mid 10s car has been running great at the start of the season all the sudden i have a problem. When i jab the pedal to the floor it falls on its nose then picks right back up if i push the pedal down slow it is fine I have taken the carb apart and cleaned everything even put new accelerator pumps in and new power valve in even cleaned pump nozzles it is a quick fuel 850 check timing check valves even checked msd box everything checks ok also put in new plugs drained all fuel and changed fuel filter even changed fuel any one have any help
THANK'S TO ALL WHO POSTED I FOUND THE BOTTOM OF THE INTAKE GASKET WAS LEAKING BUT I DID USE ALOT OF EVERYBODY'S IDEAS AND MY CAR IS RUNNING BETTER THAN IT EVER HAS. Thank's for all you help Last edited by Watson Racing; 05-28-2009 at 12:29 PM. |
Had a nearly identical problem this past weekend (although on a Dominator). Did three things, and it went away -- unfortunately not sure which one was the solution. What I did: a) put in somewhat bigger idle air bleeds, b) put in bigger accelerator pump squirters, and c) asked the driver to roll into it rather than stomp it. Problem solved.
Chris Williams 6304 SC, TD, ET |
#3 | |
As far as the original post, make sure you check the cap, rotor, wires, etc... other things can cause your issue. Excessive plug gaps can put a high load on the ignition system especially with the newer Digital ignitions. I melted an HEI cap center terminal with a Digital 7. |
Ummm... I said "problem solved". But, gee, thanks?
#5 | |
Make sure one of you idle air bleads are not plugged. It don't take much. BB |
Liked 11 Times in 8 Posts
Quick way to check for plugged idle air bleed run the adj. screw in if no change in idle spped someting is restricting the circuit. Had this on a SS car at indy took carb apart to inspect, cleaned out never did see anything but after reass. carb problem was gone. Joe
Joe Buchanan SS/BX 3117 |
make sure your idle air screws are about 1 1/2 turns out from fully closed, and then put a bigger front squirter in the thing, you should be ok then
I go with bigger squirters
I agree...
Low and Slow ![]() |
Banned
Clean Fuel Filter ?
