Old 04-20-2009, 05:09 AM   #1
XSTOCKER
XSTOCKER's Avatar
Liked 8 Times in 3 Posts
Default 440 motor mounts
Thanks guys! Exactly what I was looking for.
Looking for a source for quality 440 motor mounts and 4-speed trans mount for a 500hp 68 GTX street car.
Thanks
XSTOCKER is offline   Reply With Quote
Old 04-20-2009, 06:36 AM   #2
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Default Re: 440 motor mounts
Schumacher Creative Services.They have a real nice set of engine mounts that are fail safe and work well.They have the trans mount too.
www.engine-swaps.com
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 04-20-2009, 05:11 PM   #3
Philip Saran
Liked 14 Times in 11 Posts
As Chris said, Schumacher in Seattle WA has what you need, they also offer
a bolt in torque strap.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 04-20-2009, 10:32 PM   #4
Jim Storms
Liked 4 Times in 2 Posts
Cool Re: 440 motor mounts
Yes Schumacher products work well, just bought 2 sets last week 1 for the big block challenger and 1 for the duster they fit perfect.
Jim Storms is offline   Reply With Quote
Old 04-28-2009, 12:56 AM   #5
Qwik426
Banned
I used to use a solid steel Moroso motor mount on the driver's side of the cylinder block and left the stock rubber unit in place (on the right). No need for two steel mounts--especially on the street! To me, this set-up is a lot better than having a chain attached from your water pump housing bolt to K-frame or bracket attached/welded to your left frame rail, and which always needed periodic re-tightening to remove the slack in the chain.
Qwik426 is offline   Reply With Quote
