Old 02-13-2009, 09:11 PM   #1
Billy Harper
Liked 138 Times in 22 Posts
Default light weight spool & gears
who makes good light weight spool & gears
BILLY HARPER
Billy Harper is offline   Reply With Quote
Old 02-13-2009, 09:30 PM   #2
Shawn Blair
Shawn Blair's Avatar
Talking Re: light weight spool & gears
Mark Williams aluminum spool. They also lighten gears.
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 02-14-2009, 10:02 AM   #3
danny waters sr
danny waters sr's Avatar
Thumbs up Re: light weight spool & gears
Moser engineering///// the best !!!!!
Old 02-14-2009, 01:06 PM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: light weight spool & gears
I would second the moser stuff. If you use the moser alum spool you will most likely have to send them your axles to have the splines cut a little longer as they run the splines in the spool all the way from one end to the other. It cost a little more to do it this way but looks to make it alot stronger and less likely to strip the splines out of the alum spool as I have seen with some of the others.
Old 02-14-2009, 02:11 PM   #5
Rod Greene
Liked 242 Times in 81 Posts
Mark Williams sets the standard that others shoot for. I have run the MW aluminum spool and light weight axles since 1999 thousands of hits never a problem. That is with a 7000 rpm stick shift launch. Now that the car is sold and has an slush-o-matic in it the parts should last forever.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 02-14-2009, 02:48 PM   #6
bsa633
Banned
M/W is far better quality than Moser..but more expensive too..used both..no real problems with Moser...I just like to have better quality stuff...
bsa633 is offline   Reply With Quote
