Old 12-19-2008, 08:00 PM   #1
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Help from any FORD racers..
I have been struggleing to get my car to run the numbers, and really want to race at some divisionals this year. I am working with small blocks for now, and trying desperatly to get the car to run mid 10's so I can run S/ST. seems all of our prior attempts have either fallen short, or didnt last long enough to race.
So far we have tried a mild 306, a well built 306, a 331 stroker, and a mild 347, best we have gone is 11teens. I really dont want to keep throwing money at this anymore, and cant afford to completely switch to a big block yet, or even make the move to put a Chevy in it, which I have seriously thought about lately.
Here is what I still have...
Canfield 210CC heads, that flow 310, a Parker Funnel web for the 302 block, a nice .672/.687 Mechanical roller that will top out at 8000 rpm. Hamberger oil pan for the 302 block, Flexplate, and ballancer. I have a new Glide with a 5000 stall converter, or I have a good C-4 with a 4500 converter. I have several carbs, 650, 750, and a 900. I have been thinking of building a 347 with high compression, and using what I have, but really dont want to try this again only to just fall short of being able to run 10.90's.
Any suggestions?
I have also thought about going with a 351W block and using a 427 stroker kit, but this would involve finding another block, oil pan, and intake.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 12-19-2008, 09:04 PM   #2
Sharx
Default Re: Help from any FORD racers..
With a car that is going to tip the scales at 2800+ lbs. You need some torque to get that car moving. It's easy to spend someone else's money but you need some cubic inches. A windsor stroker would help but I'm not sure you can flow the numbers with that head to make a 427" small block really run. The windsor is going to need a different intake, and some other parts. Maybe now is the time to sell as much of that small block stuff to someone and build that big block. A stump pulling BBF isn't as expensive to build as all the Chevy guys will tell you. What kind of flow can you get out of those heads, 310 cfm might make enough with a 427 or maybe some port work can get the flow you need?
Sharx is offline   Reply With Quote
Old 12-19-2008, 09:56 PM   #3
B CHILLIK
B CHILLIK's Avatar
just my .02 my brother has a small block ford 311ci in a 88 body mustang...the car weighs 2700 with him all steel except hood scoop....he has a liberty trans and runs 10.08@129.54......a good combo is everything..the carb is a 950....
how big tires and what gear do you have,this will determine alot
B CHILLIK is offline   Reply With Quote
Old 12-20-2008, 08:39 AM   #4
Bryan Gillespie
Banned
Mill the heads 20 thou.
get the 750 carb. converted to Alch.
Launch @ 4800 rpm
Shift @ 7200
Let er eat!
Bryan Gillespie is offline   Reply With Quote
Old 12-20-2008, 10:06 AM   #5
Rich67stang
Liked 116 Times in 27 Posts
I have a svo351 stroked to 435, I ran in IHRA hotrod. It goes 9.34 @ 141 and 10.90 @ 136. It has blue thunder heads. I ran a c-4 from dynamic converters and shifted on time. I shifted third gear on rpm @ 7200.
I have used every SBF combo and to make them run you need alot of comp. and stroke to get them moving off of the stop. My car weighed 2992#. Glen fergueson runs a 351 stroked with yates heads also and he goes 10.90 @ 134. You also need to spin the crap out of that 306,331,347 to run #'s...I build alot of NMRA motors for guys. Your welcome to take my 435 for 10k TK...I am going SS racing. I would put those heads you have on a 4.00 stroke, 4.125 bore motor with a .721 or so lift cam with .270-.280 duration@ .050., super victor intake, mvh spacer,gary stinnet gas carb. Good luck. I will tell you what DOES NOT WORK ON A FORD. lol
SS/EM 161
Quick Rod 161
Rich67stang is offline   Reply With Quote
Old 12-20-2008, 10:59 AM   #6
Freddie
Freddie's Avatar
Thanks guys, sounds like I am lacking in compression and cam for now, maybe the gear as well. This car all last year kept having trans issues and only got three or four good runs out of it.
For some reason it never wanted to pull much past 5700 rpm, I thought it may be the hydrolic roller that was in it, never put the mechanical one in it yet.
I am looking at a 408 with aftermarket 4 bolt caps, and a good steel crank. will use my mechanical cam, and heads, have to get a new intake and all.. And switch to the glide with the 5000 stall converter, Do you guys think I need more gear? 3.73's with a 28x10.5 tire?
Old 12-20-2008, 11:26 AM   #7
Dave Steltz
Dave Steltz's Avatar
Friend of mine runs a Mustang II with a 302....10.30's I think best times, If I remember right 10.90's at about 126...I believe he runs a 800 holley...Lots of rear gear (5.14's) and keep the 3 speed, and lots of convertor (at least 5800-6000 )...little motors need lots of help getting going on the bottom of the track..
You have lots of head and cam, it needs to run up there in the RPM, you should cross the line at 7500 at least...
Just my .02...
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 12-20-2008, 06:16 PM   #8
Freddie
Freddie's Avatar
I have not run the mechanical roller in this car yet. The motor has been running with a Motorsport hydrolic roller one of thier F cams.
Old 12-20-2008, 10:00 AM   #9
Robbie Welch
Liked 262 Times in 124 Posts
keep the Ford the 347 should be able the get you there depending on the weight of the car. If you can't get the 347 in the med tens try a 393 or a 408 W. I run a 378W with not much to it cast crank old TFS heads and small tude 1'5/8 headers and its been 9.95 131 usually runs 10.10s. Good luck Robbie
Old 12-20-2008, 07:31 PM   #10
Mike Graham
Liked 341 Times in 67 Posts
Your 347 should easily run low 10"s
Try a roller with 270 deg @.050 ex 278 @ .050 108 lobe sep.
a converter that flashes to at least 6000
5.43 or 5.67 gear
Be careful of the hamburger pan. The pick up is typicaly way too long.
The ford pump tends to cavitate.
Mike Graham is offline   Reply With Quote
