Old 10-30-2008, 01:34 AM   #1
Ken Haase
Default torque-to-yield bolts query
I just picked up a used Chev 454HO crate motor. Does anybody know if those come with torque-to-yield head bolts?
Also, any idea how much increase in lift can the stock hydraulic roller lifter set-up tolerate? I'd like to get to the .580-.600 range if possible. Or am I going to need the retro-fit lifters? Thanks for any help.
Ken
Ken Haase is offline   Reply With Quote
Old 10-31-2008, 01:25 AM   #2
Moparteacher
Default Re: torque-to-yield bolts query
TTY fasteners are usually used where an aluminum part (cylinder head ) is being fastened. Aluminum expands and contracts greater than cast iron. This expansion requires a bolt that will stretch and retract while maintaining clamping force.
I doubt your 454 utilizes TTY bolts if it has iron heads. Are the heads iron?
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
Old 11-02-2008, 02:42 AM   #3
Ken Haase
Yes, Gary, the heads are iron. And, my recollection regarding the appearance of single-use bolts is that they are dull looking, almost like they have been bead blasted. Am I correct on that?
I was disappointed that these Gen VI head bolts still go into water, unlike the aftermarket blocks.
Thanks for the reply. Ken
Old 11-02-2008, 09:23 PM   #4
BillK
Liked 30 Times in 17 Posts
Ken,
They are not torque to yield, however ......
Most of the later model 454's use the "torque plus angle" method of tightening the head bolts.
There is a big misconception that any time a fastener uses the "torque plus angle" method of tightening ( such as 30 ft lbs plus 90 degrees) that it means the fastener is torque to yield. This is not always the case !!! This is simply a more accurate method of getting the required stretch on the fastener.
There are a lot of fasteners (Oliver rod bolts for one) that use the "torque plus angle" method of tighteneing, but are definitely not torque to yield.
Then there are some Honda head bolts that are strictly torqued to a certain ft lb figure, but those bolts are torque to yield and have to be replaced after each use.
Also, torque to yield bolts are certainly used on cast iron heads.
Bill Koustenis
BillK is offline   Reply With Quote
Old 11-05-2008, 01:46 AM   #5
Ken Haase
Bill K., thanks for the info. Very informative. Maybe I'll just buy ARP fasteners.
Along the same lines, is there a steel shim head gasket for the Gen VI blocks?
Thanks again. Ken
