Liked 54 Times in 7 Posts
Has anyone ever seen a plastic bushing that you can use when you take your stock seats and cut slots for the shoulder straps to feed thru?
I am envisioning a plastic oval tube 1/2" tall x 3" wide with a flare on the end to insert into the seat to keep the harness straps from rubbing on any inside the seat. I have high backed buckets (77 Camaro) and the tech guy at my local track recommended that I feed the belts thru the seat because the seats are pretty wide at my shoulders and the belts would not keep me restrained very well. I looked online at various belt suppliers and none of them make this sort of product. Let me know if you have any suggestions on what to use. Thanks, Chad |
Liked 14 Times in 11 Posts
Chad,
I know what your looking for, but all the one's I've seen done have have been done by a upholstery shop. But that plastic part might also be something from a seatbelt harness off of a chevy.
Phil Saran Parker, Colorado Last edited by Philip Saran; 10-18-2008 at 12:43 AM. |
I think some of your older Chev pickup tk's have what your looking for (74--about 89).............
Liked 231 Times in 107 Posts
Take a piece of PVC pipe, heat it with a heat gun and then form it to the shape you'd like.
Liked 19 Times in 3 Posts
Check with your local Chevy parts guy. My 1994 Suburban has a seat belt grommet similar to what I think you are looking for Other years must have had them as well. It is a pass through for the front seat, its hard plastic and it has a lip on it. I think it'll do the job
JimmieC |
Thanks for all the various ideas. I am planning a trip out to the junkyard to look at the various vehicles that you mentioned.
Chad |
