Old 09-15-2008, 12:19 AM   #1
Kingpen
Liked 64 Times in 22 Posts
Default Muncie 4-spd Dated June '65 M-20 Wide Ratio
have complete Muncie 4 speed with assembly date stamp of(P 06 17) June 17th-1965 & N208430 VIN stamp ........3851325 main case...3857584 tailhousing w/speedo on pass side...3831707 side cover w/3/8 fine studs...3851826 front Bng retainer...no grooves on input shaft -THIS IS NOT AN M-22 ROCKCRUSHER ..IT IS A 7/8 dia pin & does not have the drain plug..ive tried to look at all the cast dates but the early muncies are a little vague somtimes so if you need additional numbers,please call me.......this tranny works good but it probably should have synchros put in for good measure........ENTERTAINING OFFERS--CALL me at 580-591-1947 and leave a message if i dont answer-machines get noisy & i dont hear the phone sometimes.......thanks Vic Penrod....see other ad for '65 396 block
Kingpen is offline   Reply With Quote
