Old 07-21-2008, 08:33 PM   #1
10secminor
Default U/SA turbo buick
1978 turbo 3.8 regal,clean car has gon .96 under VERY easy to drive .65 under in bracket mode with a muffler!.96 under on street tires.Very clean good beginner,or low matinace stocker.Many ,many spare parts new EVERYTHING on car wheels,tires,fuel system,paint,gauges.Xtra motor&parts,many 2&4 bbl carbs,manifolds Car currently runs u/sa could be v,r?s?t with weight or 2 to 4 bbl swap.With some tuning im sure a National Record could be reached.Car has never been pushed hard low runs on motor.Please call with any questions.Thanks 661-496-5642 Car is in Bakersfield CA.
10secminor is offline   Reply With Quote
Old 05-12-2016, 09:55 PM   #2
Chevyman
Default Re: U/SA turbo buick
I have one that I am putting together at this time. Have a couple of questions If you could help me. I am running 4 barrel either Q or R auto.
1. How much timing and retard per lb boost?
2. How much does your car weight ?
3. How much hp/tq does your engine make?
Thanks
Chevyman
Chevyman is offline   Reply With Quote
Old 05-13-2016, 10:02 AM   #3
Neil Smedley
Liked 22 Times in 7 Posts
I originally built that car. If you PM me with your phone number I would be glad to help you and keep you from making costly mistakes............
Neil Smedley is offline   Reply With Quote
Old 05-15-2016, 07:22 PM   #4
Buick6
Liked 16 Times in 7 Posts
Thanks
Chevyman
The best investment you could make for one of these older Buick turbo cars would be a modern knock/boost controller from J&S Electronics. Detonation kills those motors and the J&S unit gives individual cylinder spark knock retard and a whole lot more!
http://www.jandssafeguard.com/safeguard.html
Buick6 is offline   Reply With Quote
