In today's NHRA website:
http://www.nhra.com/content/news/28815.htm NHRA Technical Reminder: Battery Location 5/8/2008 -------------------------------------------------------------------------------- Technical reminder to all Stock and Super Stock classes: All batteries must be in their original location or may be relocated to the trunk per NHRA Rulebook: NHRA Rulebook pg. 88 Section 4 - General Regulations; Electrical/Control: 8:1 Batteries “Batteries may not be relocated into the driver or passenger compartments.” NHRA Rulebook pg. 144 Section 9A – Stock Cars; Electrical: 8 Batteries “Must remain in the stock location and be of sufficient capacity to start car at anytime. Second battery permitted if securely mounted in trunk.” NHRA Rulebook pg. 154 Section 10A – Super Stock; Electrical: 8 Batteries “Trunk installation permitted; two batteries permitted.” -------------------------------------------------------------------------------- National Hot Rod Association http://www.nhra.com/ |
Liked 60 Times in 12 Posts
I take it, they are looking at batteries for the next few races ?
2894 STK |
#3 | |
Liked 276 Times in 27 Posts
A S/S car was found with the batteries mounted in the wheel tubs ahead of the rear tires...NASCAR style. That modification was ruled to be out of compliance with the rulebook. Travis (Disclaimer: Opinions expressed by me on this forum are exactly that, my opinions.) |
Ahead of the tires? Good reason to look then.
2894 STK |
#5 | |
#6 | |
Although it has been a while since I read his suspension book, as best I remember Dave Morgan wrote that an ideal place to put ballast was from the centerline of the rear axle to just ahead of it. The heavier the car is at that point, the harder it will plant the tires when the rear suspension tries to spread on a launch. If the car goes into a wheelstand the weight is still right where it is needed. His theory is putting ballast closer to the rear bumper on a car with a long overhang is a waste and causes the car to pivot on the rear tires. Travis (Disclaimer: Opinions expressed by me on this forum are exactly that, my opinions.) |
Liked 66 Times in 37 Posts
Does this mean you have to have plates and acid in the front battery???? See, this rule book is so vague...
#8 | |
