Old 04-22-2008, 06:01 PM   #1
RuggedRacing
RuggedRacing's Avatar
Default F.S LM-1: Digital Air/Fuel Ratio Meter w/ RPM Converter
The LM-1 is the industry's first and best complete wideband tuning system. A single self-contained unit combines a wideband air/fuel ratio sensor controller, a 6-channel data logger, and an easy-to-read backlit LCD display. The RPM converter is a cable that contains a circuit to convert a tach signal into an analog RPM signal that can be logged by the LM-1. This cable also has 4 additional terminal screws to tap into and log other 0-5 V analog sensors from your vehicle. The unit is brand new in the box. Asking $400. Call 516-484-0655 or e-mail RuggedRacing1900@aol.com. Thanks
RuggedRacing is offline   Reply With Quote
Old 04-23-2008, 07:29 AM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: F.S LM-1: Digital Air/Fuel Ratio Meter w/ RPM Converter
does this unit have 1 or 2 oxygen sensors
Old 04-23-2008, 07:48 PM   #3
RuggedRacing
it only comes with 1 but it is setup for 2
